Electric Field between two opposite, gaussian distributed charged spheres
2 replies · 5K views
Nick White
Hi,
I understand how to get the electric field between two spheres of uniform charge,
[tex] \vec{E} = \frac{\rho \vec{d}}{3 \epsilon_0}[/tex]
which is simplified because at a point [tex]\vec{r}[/tex], the vectors from each charge center combine to give the distance, [tex]\vec{d}[/tex], between centers (since [tex]\rho[/tex]'s can be factored).
So far, calculating this for two overlapping spheres of gaussian charge distribution seems non-trivial since you can't make this factorization and simply obtain an expression proportional to [tex]\vec{d}[/tex]...
Am I correct with the complexity of this problem, or is there some way more efficient to approach this problem?
I hope to use this electric field to model a harmonic oscillator (electron sphere oscillating around stationary ion sphere) and find a frequency...
Thanks
I think you have first to calculate which is the total rho of you 3D distribution.
This seems to be the sum of the two rho's you presented. After that I guess you will have to use integration over the whole space to get the field at point P = (x,y,z).
Best Regards,
DaTario
Best Regards,
DaTario
Thanks for the response DaTario.
I've started with that method - finding the field at a point P = (x,y,z) (point [tex]\vex{r}[/tex] in spherical) by integrating the charge from the positive distribution [tex]\rho_{+}=\rho_{0}exp(-(r^{2})/(2\sigma^{2}))[/tex] and then the negative distribution [tex]\rho_{-}=\rho_{0}exp(-(r-d)^{2}/(2\sigma^{2})), assuming [tex]d[/tex] is the displacement of the negative charge center along the z-axis for convenience, but i think it get hairy because these end up being factors for the vectors [tex]\vec{r}_{+}[/tex] and [tex]\vec{r}_{-}[/tex] when you sum the electric fields to get the total, in the overlap.<br /> <br /> I was wondering if there's maybe a book problem like this, or even an article i could refer to...<br /> <br /> NW[/tex]
