Electric field due to arc of charge
The discussion focuses on calculating the electric field due to a circular arc of charge with a radius R and total charge Q, specifically for a 90-degree arc. The charge density, denoted as λ, is derived as λ = 2Q/(πR). The electric field at point P, the center of the arc, is initially miscalculated as E = λ/(4πεR), but the correct magnitude involves multiplying by √2, resulting in E = (λ/(4πεR))(√2). The integration approach using dE = (1/4πε)(dQ/R²)sin(θ) is confirmed, emphasizing the importance of correctly interpreting the final result as a magnitude.
  • Understanding of electric fields and charge distributions
  • Familiarity with calculus, specifically integration techniques
  • Knowledge of electrostatics, including Coulomb's law
  • Concept of charge density and its relation to total charge
  • Study the derivation of electric fields from continuous charge distributions
  • Learn about the integration of vector fields in electrostatics
  • Explore the concept of electric field magnitude and direction
  • Review examples of electric fields due to different geometric charge configurations
Students studying electromagnetism, physics educators, and anyone preparing for exams involving electric fields and charge distributions.
Nikita23
A circular arc of charge has a radius R and contains a total charge Q. If the angle of the arc is 90 degrees find:
a) the charge density of the arc
b) the electric field at point P in terms of the charge density L and the radius of the arc R
L should really be lambda and P is the center of the arc.
E = (1/4pi Epsilon naught)
s is the arc length
a) (I got this part right)
Q = Ls, L = Q/s
s = 1/4 circle = (1/2)pi R
L = 2Q/pi R
b) (I didn't get this part right)
I said that because the arc is symmetric, the electric field in the x direction has the same magnitude as the electric field in the y direction, so I only solved for one of them.
I decided to integrate dE = (1/4pi Epsilon) (dQ/R squared) * sin theta (for the x direction) from 0 to pi/2
I said that dQ = L * dS and that (this may very well be the part where I went wrong) ds = R*d theta for small theta so that I could integrate in terms of d theta.
When I integrated I got Ex = L/(4 pi Epsilon R) *-cos theta evaluated from 0 to pi/2
That last part ended up being 1, so for my answer I got Ex = L/(4 pi Epsilon R), which was wrong.
Hope you followed that. These are test corrections, so I might have made dumb math mistakes during my panic.
I believe the correct answer is something like what I got but multiplied by square root of 2.
I follow your (very well executed) reply to that question but it still leads me to where I got in the first place.
I come to E = \int^{\pi/2}_{0}\frac{\lambda}{4\pi\epsilon R}\cdot sin\theta\cdot d\theta
I figured out exactly what happened. They were asking for the magnitude of the electric field. All you had to do was take your answer,
\textbf{E} = \frac{\lambda}{4\pi \epsilon_o R}(\textbf{i} + \textbf{j}),
and find its magnitude! Don't you hate when you do things like that? You can't imagine how many times I've gotten back a test and was like, "Why the hell'd I do that?"
This may sound incredibly dumb, but how do I exactly go about doing that? We weren't given any values. The answer should be "in terms of the charge density lambda and the radius of the arc R."
On the test the teacher corrected my answer of E = \frac{\lambda}{4\pi\epsilon R} by adding \sqrt{2} \chi or perhaps \sqrt{2} x
\sqrt{\textbf{E}\cdot\textbf{E}} where \textbf{u}\cdot\textbf{v} denotes the dot product.
I doubt she would have added anything besides \sqrt{2} because that would be introducing an extra variable. Plus, she wanted it in terms of \lambda and R.
  • · Replies 68 ·
