Is This Electric Field Representation Accurate?
The discussion centers on the accuracy of an electric field representation involving positive and negative charges. Participants analyze the field lines, noting that while the original diagram is mostly correct, certain grey lines incorrectly suggest convergence instead of divergence, indicating a need for adjustment. They emphasize that field lines should originate from the positive charge and that the density of lines should reflect the charge magnitudes accurately. The conversation also touches on the challenges of representing 3D fields in 2D diagrams and the importance of considering the behavior of field lines at infinity. Overall, the accuracy of the electric field representation can be improved by refining the depiction of the lines and their origins.
laser
conceptual
E=F/q
I have attached an image of what *I think* the electric field looks like. Would this be correct? I am convinced about everything here, apart from the ones on the far right. All the other ones loop from the +ve charge to the -ve charge, but where do the grey lines on the right loop to (the ones that point to the right)? One thing I can think of is that they come from infinity and don't loop from anywhere!
Here you can play with your setup and use a sensor to 'measure' ##\vec E##.
A good thing to do would be to study equipotential lines and relief maps for a confguration like yours
Likes laser, PhDeezNutz and MatinSAR
Imagine the charges were so close together that they could not be distinguished spatially. What would the field look like? That’s how the field at infinity needs to behave.
  • Love
Likes Delta2, MatinSAR and PhDeezNutz
Also consider that the positive charge +4Q starts 4 lines for every 1 line that the negative charge -Q stops. The grey that come into the picture from above and below and curve to the right cannot be there because they have to originate at the positive charge. You have to remove them. However, the grey lines that come in from above and below and curve to the left are OK so leave them alone.
Remember that far away you can think of the as a point charge of +3Q(sketch it) and a dipole Q/-Q (sketch the dipole field) . The far field will be the sum and just look like a +3Q point charge when very very far away. Voila! the poor man's multipole expansion tells you what you need to know I think.
Far away the dipole field is negligible compared to the monopole field (it falls off as 1/r^3 compared to the 1/r^2 of the monopole). Only the monopole is relevant for the far field behaviour of the field lines.
This was the poor man's multipole.. Only very very far field (my nomenclature) is pure monopole. Of course these refinements are correct, but perhaps too much information for the OP sketch.
Ok, but apart from the proportion of lines that reach the -Q being too high (as @kuruman notes), the diagram in post #1 is essentially correct, no?
After going on this website https://phet.colorado.edu/sims/html/charges-and-fields/latest/charges-and-fields_all.html and playing around with the sensor, I think the electric field looks like this?
I think the "radial lines" aren't actually radial but just look radial. The question is: do they eventually loop back to the negative charge?
Alternatively, they could just go to infinity on the right hand side.
Field lines never cross
Good point - ignore some parts of my diagram then :D. That ruled out one possibility. However, there are two left - do the electric field lines on the left hand side go to infinity on the LHS, or do they flip at some point and go to infinity on the RHS?
As I wrote in post #8, your original diagram was essentially correct. You just need to arrange that only about a quarter of the lines from the left pole reach the right pole.
No. Any field lines reaching infinity need to have a different straight line asymptote. If not the lines converge, indicating a field increasing at infinity. This is not clear to me fron the original diagram.
I don't think it was correct after playing around with the electric field thing.
I tried that link and it seemed to me it confirmed the essential features of your diagram. The curves are rather different, but that's less important.
Where do you think your diagram looks wrong?
True, the two grey lines on the right look like they are converging when they should eventually be diverging. But arguably that's just because the picture doesn’t go far enough in that direction, no?
Perhaps, but that feature is arguably so important that if it the picture is not drawn so far out that it is obvious, then it should be extended.
Likes hutchphd and haruspex
This is true for the full 3-dimensional picture. It will not generally hold in a 2D-slice of the field lines. This is one of the reasons I always found field line density in images a bit misleading.
Likes hutchphd, Herman Trivilino, PhDeezNutz and 2 others
Sure, that is a problem when drawing 3d lines on a 2d surface. The convention is that one takes a thin slice, in this case one that contains the line joining the two charges, and draws only the field lines that are in the plane of the slice ignoring all others. Doing this reduces the radial dependence of the field from ##1/r^2## to ##1/r##. The strength of the field is proportional to the angle it subtends, not the solid angle. This violates Gass's law but it retains the qualitative concepts that "the field is stronger where field lines are stronger" and that "twice the charge means twice as many lines per angle".
Shown below is a 3d plot of a dipolar field that I generated with grapher.app on my mac laptop. It might be a more correct representation of the filed on a 2d surface but there is too much clutter for my taste.
Likes Delta2 and PhDeezNutz
The rightmost grey lines. Also - I think my curves were kinda off.
It's tough to get the curves accurate without a lot of calculation. But you can correct the asymptotic appearance of the lines by ensuring they look more like the field from a single charge.
I had trouble creating a field line density plot for the case where the left charge has four times the magnitude (but opposite sign) because as soon as I made the charges to the values of the charges in my script the whole thing went haywire. I would agree that field line density should be more around the bigger charge.
In the meantime here is one I created for a physical dipole where both charges are equal in magnitude but opposite in sign.
I created the field in 3D and used the "streamslice" feature in matlab for the plane ##z=0##. Surprisingly "streamslice" does better at creating field line plots than "streamline". For the case of two equal but opposite charges "streamline" was giving me all sorts of problems but "streamslice" by default gave me a good picture without me having to tinker with the settings/options.
I may have to do some tinkering with "streamslice" for the case of one being +4Q and the other being -Q.
kuruman said:
I found the figure below here
http://www.phys.nthu.edu.tw/~hf5/EM/lecture note/EM02.pdf
The black circles are my addition. Note that twice as many field lines exit the circle surrounding the +2q as enter the circle surrounding the -q charge.
That’s not really accurate though. Close to the charges the field lines should be distributed as for a point charge (the point charge field dominates as it grows to infinite strength). In this picture they are not.
The figure is also mossing the effect talked about earlier in the right part. All in all, not very accurate.
Edit: Another obvious error is that, since the overall charge is q, a flux corresponding to q should exit to infinity. This also means that a flux corresponding to q should go from the 2q charge to the -q charge, which in turn means that for the field lines exiting the 2q charge the boundary between those field lines that reach infinity and those that end up in the -q charge should be vertical in the picture. They clearly are not.
A tangent to the field lines is radial at the location of the point charges. Likewise for the way field lines intersect equipotential surfaces.
They do for an infinitely large drawing. For a finite-sized drawing there will be field lines leaving and entering the edges of the drawing.
Edit: As explained, your @laser's initial diagram is largely correct. The improvements that could be made are:
  • ensure that lines heading off to infinity appear to diverge; specifically, the two grey lines going off to the right, having converged initially as shown, should then diverge
  • those two lines do not seem to have an origin; it should show where they emerge from the larger charge
  • the picture should extend far enough to show the path of those two lines from where they leave the 4Q charge to where they converge then diverge on the right
  • add more lines emerging from the left and heading off in different directions, so that the viewer can see how, on zooming out, it starts to look like a monopole field
As regards the details, it depends what you think the 2D picture represents. I see three options, all projections onto the xz plane of a 3D region (I define the y axis as normal to the page):
  1. The consensus seems to be a thin slice of constant thickness parallel to the xz plane; this is incompatible with all lines either reaching the other charge or going to infinity: there would be lines emanating from each charge which just disappear, particularly near the x axis
  2. A 2D projection of the whole 3D reality; that solves the orphaned lines problem but would lead to crossing lines
  3. as (1), but thin segments (like orange segments) instead of a constant thickness; the thickness would be proportional to distance from the x axis;
    • it solves the orphan problem
    • compared with option 1, the density of lines at a given distance from the x axis is increased in proportion to that distance
In all cases, the number of lines attached to each charge is proportional to the charge magnitude. E.g. in option 1, if we take a slice thickness dy and draw each charge as radius r then the lines at each charge show the flux through the same area in the 3D reality, ##2\pi rdy##, and four times the charge means (near the charge) four times the flux density.
Likes laser, Delta2 and hutchphd
I assume you mean normal to the equipotentials.
That would be true of a system with net zero charge, but here only a quarter of the lines from the 4Q charge reach the -Q charge; the rest go off to infinity, as for a monopole.
Likes Herman Trivilino and hutchphd
haruspex said:
As explained, your initial diagram is largely correct.
@PhDeezNutz is not the OP.
Thanks - edited suitably.
