Electric Field outside charged metal sphere
The discussion revolves around calculating the electric field outside a charged metal sphere with a radius of 10 cm and a charge of +2μC. The electric field is determined using the formula for a point charge, where the distance from the center of the sphere to the point of interest is 15 cm. The calculated electric field value is 8.0 x 10^5 N/C, which does not match any of the provided answer choices. Participants express confusion over the discrepancy and suggest a possible error in the problem's definition. Clarification on the expected answer is sought, indicating a need for further understanding of the problem.
dpb613
A metal sphere of radius 10 cm carries a charge of +2μC uniformly distributed over its surface. What is the magnitude of the electric field due to this sphere at a point 5.0 cm outside the sphere's surface?
8.0 x 109 N/C
4.2 x 106 N/C
8.0 x 107 N/C
4.0 x 109 N/C
4.0 x 107 N/C
Based on my understanding that a charged sphere can be treated as a point charge (a charge concentrated in one point) at its center I used the equation for electric field of a point charge:
##\vec{E}=\frac{kq}{r^2}\hat{r}##
Where k is the electrostatic constant 8.99 x 109Nm2/C2 (N=Newton, m=meter, C= Coulombs)
and r is the distance from the point charge.
Note:##\hat{r}## is the direction and is irrelevant to this question since it is asking the magnitude.
2μ=2 x 10-6
The distance from the center of the sphere is 15 cm or 0.15 m
All that said I plugged in the values as follows (sorry about the formatting Latex refused to do this one):
(8.99*10^9 * 2*10^(-6))/0.15^2
And got a result (viewable here http://wolfr.am/Znug5V)of 8.0 x 105 after rounding to two significant figures. This is not one of the choices given. Please show me my mistake. Thank You.
I got the same answer so I suspect someone made a slipup in defining the problem.
Still, I would appreciate feedback if anyone understands what they expect me to answer.
