Electric Field & Potential: Solve for Radius
twisted079
The electric potential immediately outside a charged conducting sphere is 250 V, and 10.0 cm farther from the center the magnitude of the electric field is 440 V/m.
(c) Determine all possible values for the radius of the sphere. (Enter your answers from smallest to largest. If only one value exists, enter "NONE" in the second answer blank.)
V = keQ / R and E = keQ / R2
Im assuming that since there are two answers (Im sure it is two definite answers), it has to do with the squared distance in the denominator of E; (+/-) a certain number. There is most definitely proportionality here.
My attempt hasnt gotten me far. I found the electric potential at the +10cm where the electric field is 440. That hasnt gotten me anywhere. I try to set up a system of two equations where 1) 250 = keQ/R1 ----> R = 210/keQ and 2) 440 = keQ/(R22+10) *radius should be given in cm*-----> (R22+10) = keQ/440
I have no idea where to go from here. My head hurts from this problem and I put so much time into it and got basically no where. Please help.
You found the correct equations for V and E, but you applied the second one wrong. In the first case, R1=R, the radius of the sphere, but in the second case R2=R+0.1. You have to use meters as the formula is valid for SI units. And you have to square R2 which is R22=(R+0.1)2.
So you have the equation
\frac{kQ}{R}= 250
\frac{kQ}{(R+0.1)^2}= 440
Eliminate kQ. You get a quadratic equation for R. Solve.
ehild
To solve this, I first used the units to work out that a= m* a/m, i.e. t=z/λ. This would allow you to determine the time duration within an interval section by section and then add this to the previous ones to obtain the age of the respective layer. However, this would require a constant thickness per year for each interval. However, since this is most likely not the case, my next consideration was that the age must be the integral of a 1/λ(z) function, which I cannot model.
