What is the electric flux through a surface with a point charge at its center?
The discussion focuses on calculating electric flux through various surfaces in the presence of electric fields and point charges. A participant struggles with finding the correct flux through a flat surface in a uniform electric field, initially miscalculating by not considering the normal direction of the surface. The correct method involves using the dot product of the electric field vector and the area vector to determine the flux in the z-direction. Additionally, there are inquiries about electric fields around a point charge and a spherical shell, with participants seeking clarification on the application of relevant equations. Understanding the directionality of electric fields and the correct application of formulas is emphasized as crucial for solving these problems.
katta002
A flate surface with area 0.14m^2 lies in x-y plane in a uniform electric field given by E=5.1i+2.1j+3.5k kN/c
find the flux through this surface
I know that flux= EA which E and A are given so I multiply The area with the victor E but I got a wrong answer
0.14m^2(5.1i+2.1j+3.5k kN/c)=7.14e-1i+2.94e-1j+4.9e-1z
but the correct answer is 490Nm^2/C,
how come can someone please help me. thanks.
3)A 10-{ nC} point charge is located at the center of a thin spherical shell of radius 8.0 { cm} carrying -20 {{ nC}} distributed uniformly over its surface.
A.What is the magnitude of the electric field 2.0 {cm} from the point charge and the direction of the field?
B. What is the magnitude of the electric field 15 { cm} from the point charge?
E outside spherical =Q/4pik\ =\ 1.3806503(24)\ \times\ 10^{-23}\ J\ K^{-1}r^2
and E inside= Qr/4pik\ =\ 1.3806503(24)\ \times\ 10^{-23}\ J\ K^{-1}r^3
R^3
A)and since 8.0cm>2.0cm it's outside so I used the outside equation
(10e19)(2e-2)/(4pi(9e-2)(8e2^3)=3.45e3
but the correct answer is 230kN/C
b) since 15cm>8.0cm the E is inside therefore
(.08)/4pi(9e-12)(.15)=4.19.e3
but my answer is wrong
2)A sock comes out of the dryer with 10^12 excess electron.
What's the electric flux through a surface surrounding the socks?
Flux= EA
but since the area was not given
flux= Qenclosed?k\ =\ 1.3806503(24)\ \times\ 10^{-23}\ J\ K^{-1}
10^12.9e-12=1.e23
but correct answer is 1.18e4Nm^2/C
please help me because I have a test on flux tomorrow and without understanding this might cause me. thanks.
Welcome to PF!
Hi katta002! Welcome to PF! :smile:
You need, not the flux through the area, but the component of flux in the direction normal (perpendicular) to the area.
So the normal to the area is … ?, and the component of flux in that direction is … ? :smile:
(and how are you doing on the others?)​
Thank you for welcoming me PF and boy am i glad to find this website
So I multiply the area by the i direction, j direction and K direction and find the sum of all direction but still didn't get the answer
i=.714
j=.294
k=.49
the sum is 1.498, I still don't get it.
and the rest that I posted I'm still facing difficulties so could u break it down for me, thanks and God bless you
katta002 said:
… So I multiply the area by the i direction, j direction and K direction and find the sum of all direction
that's not the component in the normal direction …
it's not even a dot-product of anything.
What is the normal direction (of the area)?​
pi*r^2
katta002 said:
pi*r^2
uhh? :confused:
The plate lies in the x-y plane …
so the normal direction is the z-direction (k) …
so the question is asking what is the component of flux in the k-direction?
(btw, did you find out how to post in the academic guidance forum?)
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
