Physics0001
- 4
Hi,
I'm dealing with a more or less trivial question. Let's have a look on two situations.
Thanks for your help.
- Consider a (negative) charged metal plate. If the plate is infinit in size it will produce a perfekt homogeneous electric field. If we now place a second plate parallel to the first one the electric field will influnce (positive) charge on the surface of the second plate. In an excersie they say that there is no resulting electric force attached to the second plate since the field is homogeneous and the force resulting from the field on the positive surface charge will be compensated by the force to the negative surface charge influenced on the other sied of the second plate.
- If we rub a plastic foil on some cloths it gets also charged. According to the gaussian law the electric field should also be homogeneous. After putting it onto the wall it will stick on the wall due the influnced charged and the electric force.
