What Happens When ω²LC=1 in an RLC Circuit?
  • Thread starter Thread starter whatisreality
    Electric Impedance
When ω²LC=1 in an RLC circuit, the inductive and capacitive reactances become equal and opposite, resulting in a net reactance of zero. This condition indicates resonance, allowing for maximum current oscillation at the resonant frequency without the need for additional voltage. The impedance at this point can appear as negative, which suggests a theoretical scenario that doesn't account for real-world losses. In practical terms, while the circuit can support large currents, it cannot operate losslessly due to inherent resistances. Understanding this resonance condition is crucial for analyzing RLC circuit behavior.
whatisreality
Consider a circuit with a capacitor C in series an inductor of inductance L. Explain what happens when ω2LC=1, without calculations, using your knowledge and intuition.
1/Z = 1/impedance = 1/(iωL) +1/(iωC)
i is pure imaginary.
Well, unfortunately I have no intuition. I don't know what the quantity ω2LC represents, but it appears in the equation when you rearrange to find Z. So when I worked out Z, it was -1/(iωC+iωL) when the set condition is met. Which is a bit weird, because -ve resistance makes no sense...?
I've obviously gone wrong somewhere!
Yes, a capacitor has impedance $$1\over j\omega C$$
Look here for some ideas
So when ω2LC=1 then the inductive and capacitive reactances are equal. The current is oscillating at the resonant frequency of the circuit?
That's right. Nothing wrong with your intuition.
Reactances are equal and opposite. So together they are 'zero'. ##\bf V = Z I## (bold face to mark them as complex): there can be huge currents shooting back and forth with 'no' voltage needed to whip them up. In reality you can't have a lossless system, so characteristics of an RLC circuit sneak in.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
