Electric Potential in a triangle
1 reply · 14K views · last reply
Zywo
What is the electric potential at the point indicated with the dot in the figure?
The dot is in the center of an equilateral triangle with sides of 3 cm. The top point is a +2 uC charge and the bottom points are both -1 uC charges.
V= kq/r
I used 1.299 cm the distance from the center point to the charges. I then plugged in the values for each point and added them up. I DID however use +1 for the -1 uC charges because they add to the electric potential right?
You must use -1 x 10^(-6) for the -1 μC charge. The potential from the negative charge tends to cancel the potential from the positive charge. If you imagine the + and - charges slowly moving toward each other, the potential will not change suddenly when the charges contact and cancel each other out.
