Electric Potential of two conductors
The discussion focuses on calculating the electric potential difference from infinity to the surface of a solid conducting sphere surrounded by a hollow spherical conducting shell. The solid sphere has a charge of -Q, while the shell carries a net charge of +3Q. Participants suggest using Gauss's Law to determine the electric field outside the shell, which is essential for calculating the potential. The potential difference can be derived by integrating the electric field from infinity to the surface of the sphere. Ultimately, the conversation emphasizes the importance of applying Gauss's Law and understanding the electric field behavior in this configuration.
jesuslovesu
A hollow spherical conducting shell of inner radius b and outer radius c surrounds its concentric with a solid conducting sphere of radius a. The sphere carries a net charge -Q. The shell carries net +3Q. Find an expression for the potential difference from infinity to the surface of the sphere.
http://img185.imageshack.us/img185/3596/rabbitatesthekv2.th.jpg
Sorry it's a little cut off, but you get the idea.
V = kq/r
Well, I'm not quite sure if I need to use calculus or Gauss's law or what. The best so far that I've been able to come up with is V1 = k(-Q)/a, V2 = k(3Q)/(c-b)
I know that if the inner sphere were not there, then the electric field would be zero inside the shell.
If I recall correctly from the last chapter I had, the outside surface of the shell will be charged at +2q and the inner surface of the shell will be at q
V = kq/r
Use Gauss' Law. That will give you the field outside the outer sphere, which is a function of the net enclosed charge.
AM
To extend Andrew's suggestion, there is no potential difference between the outside of the shell and the inside of the shell. So just pick up the same game inside the shell. Compute the potential difference between the surface of the sphere and the inside of the shell and add it to the outside.
Will it be something like this:
Using Gauss's Law,
E=k2q/r^r for r>c. E=-dv/dr, integrating this from inf to r, and that's your potential?
Using Gauss's Law,
Yes. Gauss' law will give you the enclosed charge:
\phi = \oint E\cdot dA = \frac{q_{encl}}{\epsilon_0}
By symmetry, E is uniform over a gaussian sphere of radius r > c
\oint E\cdot dA = E4\pi r^2 = \frac{q_{encl}}{\epsilon_0}
E = \frac{q_{encl}}{4\pi\epsilon_0 r^2}
The potential (work per unit charge) is:
\int_\infty^c E\cdot dr
Work out that integral to get the potential on the surface c
AM
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
