Lancelot59
- 640
- 1
I'm given the following problem:
A particle with charge q is located at x=-R and a particle with charge -2q is located at the origin. Prove that the equipotential surface that has zero potential is a sphere centered at (-4R/3,0,0) with radius r=2/3R.
I started by dividing the length between the two particles into two lengths: a and b. a is between the particle of charge q, and region b. b is between region a and the origin.
I then set up my potential equation like so:
V=k(\frac{q}{-R-b}+\frac{-2q}{-R-a})
I also had this equation to work with:
R=(a+b)
I set it equal to zero, and after some simplification I got:
b=\frac{2}{3}Ra=\frac{1}{3}R
So I solved for b, but I'm not sure what to do now. I've proved that that point on the x-axis has a potential of zero. How do I prove that it is a sphere?
R=(a+b)
