Electric Potential reference value (or zero).
The electric potential for a point charge is defined by the equation V = kq/r, which indicates that the potential is nonzero everywhere and only equals zero at infinity. The discussion emphasizes that the potential difference (ΔV) is the key measurable quantity, rather than the absolute value of potential at any point. To set the potential to zero at a specific point, such as r = 5, one can add a constant to the potential function, resulting in V = kq/r + 5, which adjusts the reference point without altering the functional behavior. The conversation also draws parallels with gravitational potential, where a constant can be added to set a new reference point, such as at the Earth's surface. This highlights the flexibility in defining electric and gravitational potentials based on chosen reference points.
fog37
Hello forum members,
The electric potential for a point charge is a scalar function given by $$V = \frac {kq}{r}$$
This means that the potential has a nonzero value everywhere. The potential becomes ##V=0## when ##r=\infty##. However we know that what matters is the potential difference ##\Delta V## and not the absolute value of potential at each spatial point. This is because the physically important and measurable quantities like force and electric field depend on that difference and not on the absolute value of V at each spatial point...
How would we make the potential to be ##V=0## not at infinity but at different spatial point, like ##r= 5##? How do we modify the function ##V = \frac {kq}{r}##? Like this
$$V = \frac {kq}{r-5}$$
Is that it?
Thanks,
fog37
No, that changes the functional behaviour of the potential, it would diverge at r = 5 instead of r = 0. What is physically irrelevant is a constant addition to the potential.
Oh, you are right.
For instance, something like this: $$V = \frac {kq}{r} + 5$$
So at ##r=\infty## the potential is 5 and wherever the term ##V = \frac {kq}{r}## equals ##-5## the potential will become ##V=0##
Thanks
The gravitational potential is similar. With the reference point at infinity, the gravitational potential outside the Earth's surface is ##V = -GM/r## where ##M## is the mass of the Earth and ##r## is the distance from the center of the Earth. You can reset the reference point to make the potential zero at the Earth's surface by adding a constant: $$V = -\frac {GM} r + \frac {GM} R = GM \left( \frac 1 R - \frac 1 r \right)$$ where ##R## is the radius of the Earth.
Optional exercise: let ##r = R + h## where ##h## is the height above the Earth's sufrace, and show that if ##h \ll R##, then ##V \approx gh## (note little ##g## not big ##G##), so the potential energy of a mass ##m## at height ##h## is ##\approx mgh##.
Likes Ibix
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
