Anden
- 75
Ok, a few days back I gave a helping hand to a guy wondering about electric fields and how electrons act in them.
My thought for solving the question was U * q = 0,5mv^2, but as a clever person pointed out this makes no sense if the charge is negative. I've thought about it, and even looked it up in my physics book which uses the expression but does not bother to explain it.
Well, if I knew I wouldn't be posting the question here.
But my theory so far is that if you use m * a = E * q, for a negative charge that would give a negative value for acceleration.
So to explain that I looked at the electric field lines, which always go from positive to negative.
So if you use an electron it would make sense that the acceleration would be negative since it accelerates in the opposite direction of the electric field.
So if I then put a negative sign in front of the electric field value, the acceleration would measure as positive in the opposite direction, that is acceleration would be negative for positive charges. To me that makes sense because if you "sit" at the positive pole, the electric field will "flow" away from you, while it would "flow" towards you if you were at the negative pole.
The expression can be rewritten into q * E * d = 0,5mv^2
My questions then is: Following the reasoning I provided, can I put a minus sign in front of the electric field value? Is my reasoning sound, or have I completely misunderstood everything
I'm happy for any help I can get
