Electrical Engineering - Steady-State Voltage across Capacitor
The discussion focuses on finding the steady-state voltage across a capacitor in an electrical engineering problem. Participants discuss the use of complex impedances and the application of Kirchhoff's laws to set up equations for the circuit. There is confusion regarding the voltage drops across current sources and the correct formulation of loop equations. After clarifying the equations and correcting assumptions, the voltage across the capacitor is calculated using Ohm's law based on the known current. The final expression for the voltage across the capacitor is confirmed as Vc(t) = -5.785sin(5t - 91.46).
SaShiMe
Find the steady-state voltage Vc(t) across the capacitor.
jwL,-j/wC
thats all i can do, i have no idea how to even start... T.T its depressing...
So far so good. With the complex impedances, you can treat everything like a resistor.
Write down the three loop equations for the circuit.
hmm that's what i am confused about, initially, i tried it this way, but i am not sure if its correct.
denote phase angle as < notation.
ia+ib=20<0
ic-loop
(10<0*3)+(10<0-ib)(12+j5)=0
ia-loop
ia(3+j5)=0
ib-loop
ib(15+j25-j)+(ib-10<0)(12+15j)=0
am i correct?
No, you forgot the 3-ohm resistor in the Ic loop. You didn't account for Vc in the Ib loop, and you didn't account for the voltage drop across the current source in both the Ia and Ib loops.
EDIT: Oh, I see you did have the 3-ohm resistor in there. You forgot the voltage drop across the current source in the Ic loop.
voltage drop across current source in Ic loop?
is it (10<0-ib)(12+j15)?
No, that's not quite right. KVL applied to that loop tells you it's going to be (10<0-ib)(12+j15) plus the drop across the 3-ohm resistor. In any case, I don't think the Ic loop equation is too important because you already know Ic=10 A.
The basic mistake you made in your equations is assuming the voltage across a current source is 0. It's not. It will be whatever voltage is needed so that the given amount of current will flow through the source.
oh, so i have missed out that there's a voltage drop across 20<0 and 10<0 current source? is that what you meant?
Yes, that's what I meant.
ok, but i have no way to know the voltage drop across 20<0 and 10<0 right? should i change my loop?
No, you really only have two unknowns: Ia and Ib, so all you need are two equations. You already have one from KCL: Ia + Ib = 20. The other one you can get by combining the two equations for the Ia and Ib loops and eliminating the unknown voltage drop across the 20-A source.
OHH,
ia+ib=20<0
ia-loop
ia(3+j5)=0
ib-loop
so instead of ia loop=0 and ib loop=0.
i have
ia(3+j5)=ib(15+j25-j)+(ib-10<0)(12+15j)
is that correct?
Close. The righthand side of the Ia and Ib equations shouldn't be 0; it should be equal to the voltage drop across the 20-A source:
ia(3+j5)=v20
ib(15+j25-j)+(ib-10<0)(12+15j)=v20
Then when you combine them to eliminate v20, you get
ok I've got
ib=5.785<-1.46
=(5.783-j0.147)
ia=(14.217+j0.147)
=14.29<-0.5924
i know i need ib and ic to caculate, but i don't know how...
Just use Ohm's law to calculate the voltage across the capacitor since you know the current flowing through it now.
so Vc=ib*(-j)
Vc(t)=5.785<-91.46
=5.785sin(5t-91.46)
Looks good! (Maybe check the overall sign?)
hmm,
Vc=ib*(-j)
Vc=(5.785<-1.46)(1<-90)
did i get the sign wrong?
Consider the direction of Ib and the polarity of Vc given on the circuit diagram.
ohh,
so
Vc=-ib(-j)
=-5.785<-91.46
=-5.785sin(5t-91.46) (sin because current lead voltage in capacitor)
