Electrical Equipment (Automatic Transfer Switch)
The Automatic Transfer Switch (ATS) is primarily used to manage the transition between power sources, such as switching to an emergency generator during a power outage. It ensures that the house is not connected to both the power grid and the generator simultaneously, preventing backfeed. Scenarios for ATS operation include switching when a UPS goes into battery mode, managing load drops during source changes, and adjusting voltage and frequency settings. The discussion highlights the importance of understanding these operational scenarios for effective use of the ATS. Proper configuration and usage of the ATS are crucial for safe and reliable power management.
Danielle Agamon
What are the scenarios for the ATS (Automatic Transfer Switch to operate?)
Depends on what one is doing with it. A typical application of an ATS to start up an emergency generator, and switch load onto it once voltage has stabilized in the event of a power outage.
Likes dlgoff
If you have an emergency generator, such as @Asymptotic mentioned, it is forbidden to have your house connected to the power grid and the generator at the same time. The ATS is used to switch your house loads from the grid to the generator, or the generator to the grid.
Likes jim hardy and dlgoff
Somehow, to me this seems like a question off of a test.
Likes berkeman
Agreed. @Danielle Agamon -- what is the context of your question?
The scenarios to operate ATS are
1.Switching of the ATS when the UPS goes to or from "on battery" mode
2.Dropping the load when the ATS switches sources while both appear to have power
3.Revise the voltage transfer range from medium to wide, revise frequency deviation from +/-2 Hz to +/-3 Hz on the ATS
4. Set the source preference from source A to none on the ATS
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
