Electrical field strength problem
5 replies · 2K views
MMCS
I have completed the force column in the table however I am not sure what the question is asking me for the field strength calculation. am i to use the 25μC charge or the 8μC charge in the formula 1/4∏ε x Q/r^2, this may be obvious to someone with more experience of these questions,
Thanks
Use the 8μC charge, as that's the charge producing the field that the 25μC charge experiences as per the wording of the problem.
Thanks mate.
I have calculated the force for the 1mm distance to be 1.8x10^6
so for field strength i have used (1.8x10^6)/8μC = 2.25x10^11
Does that answer look about right?
MMCS said:
Thanks mate.
Nope. You should have divided by 25μC thus leaving the 8μC charge in the calculation.
For the table a graph is required, what values do you think they want? would it be force against field strength or would distance be used against another?
At a guess I'd say two graphs would be appropriate: force vs distance and field strength vs distance. With clever axis labeling you might plot both on the same graph...
