Electrical & gravitational force:which one is stronger?
The discussion centers on the comparison between electrical (Coulomb) and gravitational forces, with the consensus that the Coulomb force is significantly stronger. However, the strength of these forces can vary based on the specific charges and masses of the particles involved. Participants note that while gravitational force is the weakest of the four fundamental forces, a direct comparison requires considering coupling strength rather than just force magnitude. There is a call for clarity, as conflicting figures in texts contribute to confusion. Ultimately, understanding the context and specific conditions is crucial for accurate comparisons between these forces.
shehri
I know that electrical/electrostatic i.e Coulob force is stronger than gravitational fiorce.But how much?There's too much contradiction within texts.
Fe=Kq1q2/r2
Ge=Gm1m1/r2
Different figures've been found in texts.Plz. give accurate figure.
Surely it depends upon the charges and masses of the particles you are considering. Why not decide on a situation, then put some numbers in and find out?
Fe=Kq1q2/r2
Ge=Gm1m1/r2
well...are you talking about the hierarchy problem? mmm... seems a bit advance for intro physics. OK, yes gravitational "force" is the weakest of all 4 fundamental forces (loosely speaking), but as previous poster said, it can also depend on the mass/charge of the objects involved. A direct comparsion can only be done when you are talking about coupling strength and not the force itself.
