How to Calculate Currents in an A.C Network?
  • Thread starter Thread starter Emzielou83
    Electrical Theory
The discussion focuses on calculating currents in an A.C. network consisting of a coil and a capacitor. The user successfully calculated the current in the capacitor as 15.1 Arg 90 degrees Amps but struggled with the current in the coil. The correct approach for the coil's current involves using the formula IL = V/(R + j XL) instead of just V/XL, leading to a result of 3.385 Arg -45.148 degrees Amps. Additionally, the conversion between rectangular and polar forms is clarified, emphasizing the importance of calculating both magnitude and angle accurately. Understanding these calculations is essential for solving A.C. circuit problems effectively.
Emzielou83
Hi,
This is a coursework question from my Eng science.
An A.C network consists of a coil of inductance 10mH and series resistance of 25 ohms in parallel with a 50*10-6F capacitor. The A.C supply voltage is 120/0 degrees V at 400Hz.
Draw a well labelled diagram
a) Calculate the current in the capacitor in polar form
b) Calculate the current in the coil in polar form
c) calculate the total current from the supply voltage in polar form.
I have all the final answers:
a) Ic= 15.1Arg 90 degrees Amps
b) ILR = 3.4Arg-45 degrees Amps
c) I = 12.9Arg 79.3 degrees Amps
I am using the formula
Ic = V/Xc
Xc = 1/2piFC
Xc works out to be 7.957 ohms
Then using Ic = V/Xc
Ic = 15.08 Amps
15.08Arg90 degrees.
the next bit is where I get stuck.
For IL I am using
IL = V/XL
XL = 2piFL
I am working XL out at 25.13 ohms
Then IL =V/XL = 4.77 Amps.
I know this is wrong but I can't see what I am doing.
Also I am not too brilliant at working out the polar side of things, if anyone knows a simple way of explaining this it would be a great help.
Thanks
Emma
Emzielou83 said:
Hi,
Ic = V/Xc
Xc = 1/2piFC
Ic = 15.08 Amps
15.08Arg90 degrees.
For IL I am using
IL = V/XL
XL = 2piFL
Thanks
Emma
The source voltage is applied to the series connection of the inductance and the resistance: XL + R.
IL = V/XL
This is wrong. Since you have a coil of inductance and resistance so, the current is given by:
IL = V/(R + j XL)
IL = 120 < 0O / (25 + j 25.13) = 3.385 < - 45.148O
Any quantity that has a magnitude and a direction can be represented in two ways:
1) Rectangular form; for example:
R + j XL
is written in rectangular form.
2) Polar form; for example let's convert [R + j XL] to polar form:
The magnitude is given by:
[ R2 + XL2 ]0.5
and the angle (sometimes also called argument):
tan-1 [XL/R]
