Electricity-sweater physisc problem
  • Thread starter Thread starter lauralovesyou
When removing a wool sweater, static electricity is generated due to the friction between the sweater and hair, causing electrons to transfer from one material to the other. This transfer results in the sweater becoming negatively charged and the hair positively charged. The opposite charges create an attractive force, pulling the hair towards the sweater. The phenomenon is a classic example of electrostatic attraction, illustrating the principles of charge transfer and electron movement. Understanding this interaction highlights the role of static electricity in everyday experiences.
lauralovesyou
Sometimes when you are taking off a wool sweater by pulling it over your head, you find that your hair is attracted to the sweater. Explain why this is so by referring to the movement of electrons.
maybe you want first to share with us what answer you should provide here :) ..
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
