Designing an Electro Magnet to Lift 1Kg Weight Precisely
To design an electromagnet capable of lifting a 1 kg weight, key factors include the number of wire turns, the type of core material, and the voltage applied. The user seeks guidance on precise measurements and calculations for effective lift, emphasizing cost-effectiveness. Recommendations suggest using a ferromagnetic core to enhance magnetic field strength and experimenting with different wire gauges for optimal performance. The importance of calculating the required current and understanding the relationship between turns and lifting capacity is highlighted. Accurate design parameters are crucial for achieving the desired lifting capability.
zouzanda
:redface: 1. i need to design an electro magnet that can lift a 1 Kg weight vertically with the minimum cost possible ANYONE GOT ANY IDEAS and i need it to be very presize i mean the measurements thanx
i already discovered that i should use and rode and turn on it a wire and conect it to a batery but i can find anythin concerning measurements and how many number of turns i need to lift a 1 kg or even how many holtage i need so please can someone point me in the right direction ?
