Electrochem - about the usage of standard pontential
  • Thread starter Thread starter crays
    Standard
The discussion centers on the confusion regarding the use of standard electrode potentials to predict spontaneous reactions involving hydrogen peroxide (H2O2) and chlorine (Cl2), iodine (I2), and potassium iodide (KI). The key point is that for reactions to be spontaneous, one species must act as an oxidizer while the other acts as a reducing agent, which is why the correct pairs of electrode potentials must be chosen. Specifically, using the potentials for Cl2 and H2O2 (1 and 4) correctly indicates spontaneity, while using both as reducers (1 and 3) does not work because there are no electrons to balance the reaction. The discussion concludes with clarification that the initial conditions dictate which reactions and potentials can be applied. Understanding these principles is crucial for accurately predicting reaction spontaneity.
crays
Hi guys, I've got this question where i am abit confused by which value should be used.
Predict if a spontaneous reaction takes place between
a) H2O2 and Cl2
b) H2O2 and I2
c) H2O2 and KI
1/2 Cl2 + e- \rightarrow Cl- (E = +1.36) --- 1
1/2 I2 + e- \rightarrow I- (E =+0.54) --- 2
1/2 H2O2 + H+ + e- \rightarrow H2O (E = +1.77) --- 3
O2 + 2H+ + 2e- \rightarrow H2O2 (E = +0.68) --- 4
As I've seen the solution, my question is, why for a) and b) i couldn't use the value for 1 and 3?
for example for a) using the 3 and 1 value, i get a positive value which means it is spontaneous, but in my book, it uses the value 1 and 4 which is spontaneous too.
(sorry for the messy E value thing)
1&3 means you are going to reduce both Cl2 and H2O2 - where are you going to take electrons from? 1&4 means one acts as an oxidizer, the other as reducing agent, and electrons nicely balance.
methods
Thanks borek. But i wonder why i couldn't revert the equation for 1? is it because it stated that it has to be Cl2 ?
Initial mixture doesn't contain Cl-. If you were asked whether Cl- can be oxidized to Cl2 by hydrogen peroxide, reversed 1 might be used as a clue.
Thanks i think i got it now, so i take the value what was given at first :)
Thread 'Confusion regarding a chemical kinetics problem'
TL;DR Summary: cannot find out error in solution proposed. [![question with rate laws][1]][1] Now the rate law for the reaction (i.e reaction rate) can be written as: $$ R= k[N_2O_5] $$ my main question is, WHAT is this reaction equal to? what I mean here is, whether $$k[N_2O_5]= -d[N_2O_5]/dt$$ or is it $$k[N_2O_5]= -1/2 \frac{d}{dt} [N_2O_5] $$ ? The latter seems to be more apt, as the reaction rate must be -1/2 (disappearance rate of N2O5), which adheres to the stoichiometry of the...
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
