Electrode Potential: Establishing E & Measuring Ecell
In summary: Once equilibrium is reached, we get a steady value of potential established. This value is given by Eeq = E° - (RT/F) * log_e(K), where K is the equilibrium constant. However, if the conditions of the system are held constant at a certain reaction quotient Qconstant, then the potential established will always be Econstant = E° - (RT/F) * log_e(Qconstant). This potential can be measured to determine the free energy change at that particular reaction quotient. In summary, the potential established at an electrode is determined by the standard electrode potential and the reaction quotient at the electrode surface. The only need for another electrode is to measure the difference in potentials, known as the cell potential, which can be used to
Big-Daddy
343
Am I right to think that the potential established at an electrode immediately when placed in solution is given by
[tex]E = E° - \frac{R \cdot T}{F} \cdot log_e(Q_{surface})[/tex]
where the potential E of the electrode results from the standard electrode potential (E°) of the reaction and the reaction quotient Qsurface at the electrode surface.
Then, once equilibrium is reached (usually fairly quickly for potential determining equilibria), we get a steady value of potential established, which is given by
[tex]E_{eq} = E° - \frac{R \cdot T}{F} \cdot log_e(K)[/tex]
Noting also that, once equilibrium conditions are established, the value of activities or concentrations at the electrode surface will be the same as their values in the bulk solution.
If the conditions of the system are held constant at a certain reaction quotient Qconstant instead of allowed to go to equilibrium, then the potential established is always
[tex]E_{constant} = E° - \frac{R \cdot T}{F} \cdot log_e(Q_{constant})[/tex]
Is this a correct understanding? And if this potential will be established on its own, is it correct to say that the only need for another electrode to join the first one is so that the difference in potentials can be measured (i.e. Ecell=E(Right Hand)-E(Left Hand) when written out)?
Chemistry news on Phys.org
Yes, this is a correct understanding. The potential established at an electrode will be given by the equation you provided. The only need for another electrode to join the first one is so that the difference in potentials can be measured. The difference in potentials is known as the cell potential, which can be used to determine the free energy change of the reaction.
1. What is an electrode potential?
An electrode potential is a measure of the ability of an electrode to undergo oxidation or reduction reactions. It is a measure of the tendency of an electrode to lose or gain electrons.
2. How is electrode potential established?
Electrode potential is established by placing the electrode in a solution containing its own ions at a known concentration. This creates an electrochemical cell, where the electrode potential can be measured.
3. What is the standard electrode potential?
The standard electrode potential is the electrode potential measured under standard conditions, which include a concentration of 1 mol/L for all solution species and a temperature of 25°C. It is used as a reference point for comparing the electrode potential of different electrodes.
4. How is electrode potential measured?
Electrode potential is measured using a voltmeter or potentiometer. The electrode in question is connected to one terminal of the device, and a reference electrode (such as a standard hydrogen electrode) is connected to the other terminal. The difference in potential between the two electrodes is then measured.
5. What is the relationship between electrode potential and cell potential?
The cell potential is the difference in electrode potential between two electrodes in an electrochemical cell. It is equal to the difference in electrode potentials of the two electrodes. If the electrode potential of the anode is higher than the cathode, the cell potential will be positive and the reaction will be spontaneous. If the electrode potential of the anode is lower, the cell potential will be negative and the reaction will not be spontaneous.
