Electromagetic movement of water
  • Thread starter Thread starter voltronforce
    Movement Water
An electromagnetic field can move water, but the strength required is substantial, making it impractical for small applications like tabletop fountains. Attempts to achieve this have been made, such as with prototype ships using superconducting electromagnets, but they achieved minimal movement. A more feasible approach might involve inducing an electric current in the water, which could be done by placing electrodes in the flow and using an external magnetic field. However, safety concerns arise with this method, and adding salt to the water may be necessary to increase conductivity. Overall, creating a magnetic water feature is challenging, and alternative gift ideas may be more suitable.
voltronforce
Hi.
I was wondering how strong an electromagnet would have to be to move water, such as a low stream from a tap or something..
I searched the forum a bit to the answer to this, and while i did discover that an electromagnetic field of sufficient strength will move water, the strength required was not described.
The reason i ask is because i was thinking of making a modification to one of those tabletop water feature fountains as a gift idea. Is this even possible? Is there a better way? Or should i just go with a voucher or something...
Thanks in advance.
voltronforce said:
Hi.
Thanks in advance.
Moving water magnetically just isn"t going to happen. Try to find a different gift :o)
It takes an enormous amount of power. A prototype ship was built using this idea (think: "The Hunt for Red October"). It used massive superconducting electromagnets and was only able to move at 2 mph.
Cool. Back to the drawing board then.. Thanks for the help guys.
One possibility would be to induce an electric current through the steam of water, now you may be able to move the water by varying an external magnetic field.
The quesion would be how to induce the current... safely.
You put electrodes in the water between the magnet poles. The electrodes have to be perpendicular to the wate flow.
I believe and old microwave oven magnet would work. You may have to put salt in the water to get enought current. I believe on the order of an amp
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
