oldunion
- 182
some of you may have heard of a guass gun, coil gun, or em mass accelerator. if not google has you covered. I am designing a system which will utilize 4 or 5 electrolytic capacitors rated for 400v per cap, a dual stage coil with ir photo gates, and some other things.
The principle is that a high voltage is discharged into a coil of copper wire (solenoid) which creates a strong magnetic field inside the coil. This in turn can launch a projectile sitting inside this coil.
The major problem with these devices is overal efficiency, 8% is the most I've ever heard of. I will be using an IGBT switch, which is the most efficient means of pulsing the energy from the capacitors.
I am also shielding the coil with a silencer looking tube of iron.
Does anyone else know of a way to further the efficiency in such a scenario
