[Electromagnetics] E-Fields & Equipotential Surfaces
The discussion revolves around calculating the electric field (E) using potential differences from equipotential surfaces in electromagnetics. The initial calculation yielded E = -1000 V/m, which was noted to be incorrect due to overlooking the proximity of the 102 V equipotential surface to the 104 V surface. Participants suggest that a more accurate E value can be obtained by considering all relevant equipotential surfaces, including the 102 V surface. There is also a recommendation to create a V(y) graph to clarify the relationships between the potentials and improve understanding. Overall, the importance of accurately accounting for all equipotential surfaces in calculations is emphasized.
lonelypancreas
This is from the book Engineering Electromagnetics by Hayt & Buck.[/B]
E = - (ΔV/ΔL)[/B]
At part (a), I took the potential difference between point A and the point directly above at the higher surface (106 V) and plugged in the needed values:
E = - (106-104 V)/(2-Ay mm) = - 1000 V/m which is ≠ -1075-Ay V/m.[/B]
Were there things that I have overlooked?
You overlooked that the 102 V equipotential is closer than 2 mm to the 104 V equipotential. You will get a higher magnitude for E if you take that into account.
I think I'm kinda lost.
So do I have to include the potentials from point A with respect to ALL equipotential surfaces? (i.e. 106-104 V, 108-104 V, etc.)? And with respect to the 102-V surface, is the coordinate of the point below point A relevant? If so, how do I get its coordinate?
Your calculation give an average value somewhere between the two ep lines considered.
Maybe drawing an V(y) graph will make it clearer?
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
