Could a DC Motor Work with Only Two Sides of Copper in the Magnetic Field?
In summary, if you have two sides of the copper frame in a magnetic field, it will work. If you only have one side, it won't work because there is no relative motion between the magnetic field and the conductor.
Brock
39
see this set-up for a DC Motor
http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/motdc.html
If the sides of the copper frame were the only copper in the field, the motor would still work correct? (stretch the copper frame out, or thin the magnets) So now we have only two sides of the copper frame in the magnetic field. Now if those sides rolled so that the same face of the copper was always facing the same magnet, would the motor still work?
What copper frame? What are you talking about?
Based on the fact that the frame cannot rotate (it's the frame and is supporting everything), there is no relative motion between the magnetic field and the conductor (frame in your example), no, it will not work.
I mean the inducting copper in the picture, maybe "wire" is a better word for it.
No. It would not. It's like asking if you jump up when you pull your boots on and then stand up before you touch the ground and jump up again, could you levitate upwards?
If I understand what you are asking correctly, then no, it won't work. If the wire was able to rotate somehow and face the same magnet, then motor would not provide any mechanical power since it is free to rotate such that it counters the torque developed by the current flow and flux interaction.
Ok wanted to be sure about that, now here's another question, or theory.
Could it be that on a quantum scale that it's a gyroscopic effect that is causeing the motor to work? A diamagnetic effect happens to the copper, but that effect happens as if B is an axis. So B causes a net "spin", or whatever, in one direction, on the atom, and when the metal is turned in this, it's like turning billions of little gyroscopes, and so current flows as the reactant force?
Related to Could a DC Motor Work with Only Two Sides of Copper in the Magnetic Field?
What is electromagnetics?
Electromagnetics is the branch of physics that deals with the study of electromagnetic fields, which are created by the interaction of electrically charged particles. It encompasses the behavior of both electric and magnetic fields, as well as their interaction with matter.
How does electromagnetics affect our daily lives?
Electromagnetic fields are present in a wide range of everyday devices, from cell phones and computers to power lines and household appliances. These fields are also used in various medical technologies and play a crucial role in communication and transportation systems.
What are some real-life applications of electromagnetics?
Electromagnetics has numerous practical applications, such as in wireless communication, radar and sonar systems, electric motors, generators, and transformers. It is also used in medical imaging, radio and television broadcasting, and navigation systems.
How does electromagnetics relate to other branches of science?
Electromagnetics is closely related to other branches of science, such as electricity, magnetism, and optics. It also has connections to fields like quantum mechanics, relativity, and thermodynamics, as it helps to explain the behavior of particles and energy.
What are some current research topics in electromagnetics?
Some current research topics in electromagnetics include the development of new materials with unique electromagnetic properties, the study of electromagnetic radiation in extreme environments, and the exploration of new applications for electromagnetics in fields like energy and medicine.
  • Electromagnetism
  • Electromagnetism
  • Electrical Engineering
  • Electromagnetism
  • Electromagnetism
