Calculating Angular Momentum of a Monopole-Charge System
  • Thread starter Thread starter XieJiaLin
    Electromagnetism
XieJiaLin
A magnetic monopole, if it existed, would produce a magnetic field B = gr/r^3, where g is the magnetic charge, and r is the distance from the monopole. Calculate the angular momentum of a system consisting of a monopole g and a charge e, both at rest.
The attempt at a solution
I know that the angular momentum points from the charge to the monopole with a magnitude of ge/c; however, I'm not sure how to show this. Any help starting out would be greatly appreciated.
Probably you mean generalized angular momentum. Perhaps you need to take into account the electric field of the charge and the magnetic field of the monopole and calculate
\frac{1}{4\pi}\int\,d^3r'[\mathbf{r}'\times(\mathbf{E}\times\mathbf{B})]
using the facts that \mathbf{B}(\mathbf{r}')=-g\nabla\frac{1}{r'}
and
(\nabla'\cdot \mathbf{E})=4\pi e\delta^3(\mathbf{r}-\mathbf{r}')
where \mathbf{r} is the position of the charge. Integration by parts may be useful.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
