Electron Flow in Short-Circuited Battery: What to Expect?
6 replies · 3K views
nshamblin
What is the speed of electron flow in an eletric curcuit? A battery (cell) with a copper wire shorted across the positive and negative posts. What will the electron flow be through the copper wire?
on Phys.org
Each individual electron moves very slowly for example in a copper wire of radius 1 mm carrying a steady current of 10 Amps, the drift velocity is only about 0.024 cm/sec.
However because there are electrons throughout the whole length of the copper wire, its a bit like pushing on the end of a pipe full of putty, the putty at the opposite end starts to move even though your end hasn't moved very far.
does the speed change? or is it constant? for instance does the speed of I depend on its volume which would in turn be dependent on E or R ?
[itex]I = nAvQ[/itex]
Where,
I = electric current
n= charged particles per unit volume
A= cross sectional area of conductor
v= drift velocity
Q= charge of each particle
so therefore
[itex]v = \frac{I}{nAQ}[/itex]
Thank you for your help. I've been imersed in labor these past 40 years having to set aside some of the questions I've had since childhood. I thank you for clearing this one up. My electronics instructor years ago said the electrons in a cucuit moved at the speed of light, which I always questioned, because of mass issues, Now I know. thanks again.
http://www.jimloy.com/physics/electric.htm
This article should explain it a bit better than I did.
