Understanding the Spin of Electron and Its Quantum Numbers
Why is the mass of the electron 9.109 x 10-31 kg ?”In summary, the spin quantum number for an electron pair is taken as +1/2 and -1/2, which is an intrinsic property of the particle similar to its mass and electric charge. The specific values chosen are based on the electron's spin value and are not arbitrary.
Stephen Raj
According to spin quantum number, the spin value of electron pair is taken as +1/2 and -1/2.
Why should we take only these values. I didn't understand what the spin of electron represents.
How much quantum mechanics do you know? It will make it easier for the answer to be at an understandable level.
Please have a look at Dirac's equation.
The value 1/2 for the spin of the electron is just an intrinsic property of this particle like, say, its mass.
Your question could have been “Why is the electric charge of the electron -1 ?”
1. What is the spin of an electron?
The spin of an electron is an intrinsic property that describes its angular momentum. It is one of the fundamental characteristics of an electron and is always present, regardless of its motion or position.
2. How is the spin of an electron measured?
The spin of an electron can be measured using a device called a Stern-Gerlach apparatus. This device uses a magnetic field to deflect the path of electrons, allowing for the measurement of their spin.
3. What are the quantum numbers associated with the spin of an electron?
The quantum numbers associated with the spin of an electron are the principal quantum number, azimuthal quantum number, magnetic quantum number, and spin quantum number. These numbers describe the energy, shape, orientation, and spin of the electron, respectively.
4. What is the significance of the spin quantum number in determining the behavior of electrons?
The spin quantum number determines the direction and magnitude of an electron's spin. This is important because it affects how electrons interact with each other and with external forces, ultimately determining the behavior and properties of atoms and molecules.
5. Can the spin of an electron change?
According to the laws of quantum mechanics, the spin of an electron is always conserved and cannot change. However, it can appear to change when observed from different perspectives or when interacting with other particles.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
