Does the Spin of an Atom's Electrons Affect its Orbital Configuration?
In summary, the conversation discussed the Stern-Gerlach experiment and its results on silver atoms with different spin values. It was mentioned that the spin-orbit effect can be enhanced in heavier atoms like uranium and can cause a fine structure effect. The presence of spin-orbit coupling can also change the energy levels and affect the total angular momentum of the atom. The conversation also touched on the relationship between spin and electron orbitals and how they can be affected by external factors such as a magnetic field.
Ryan Reed
51
In the stern-gerlach experiment, silver atoms with a +1/2 would be deflected up, and atoms with a -1/2 spin would be deflected down. With that in mind, would electrons' orbitals within an atom be affected by its spin?
With an external magnetic field: sure. It is a small effect, however.
Likes bhobba
Spin orbit effects are small.
If the electron is the first in a large atom like uranium, would the effect be larger even though it's still small? And does this effect ever get large enough to be measured?
Spin-orbit effect is enhanced as the nuclear charge increases. In heavy atoms such as U the spin-orbit effect is no longer perturbative, and the proper treatment of the problem should start from the relativistic Hamiltonian formula (Dirac equation). The effect due to spin-orbit coupling causes the so-called fine structure effect, where the energy levels are no longer degenerate in ##l##, i.e. splitting takes place. For hydrogen like uranium, these splittings might reach keV order of magnitude and yes something that big is hard to miss.
would the spin orbit effect have different results based on which spin was present?
What do you mean by that? The spin of electron is always that ##s=1/2##.
An electron's spin can either be either +1/2 or -1/2, that's what the stern-gerlach experiment tested.
It's more accurate to say those numbers as the electron spin projection in a given direction, or the eigenvalues of operator ##S_z##.
The presence of spin orbit effect in perturbative regime is expressed as the inclusion of the spin-orbit coupling term proportional to ##\mathbf{L}\cdot\mathbf{S}##. This spin-orbit coupling term does not commute with ##S_z##, therefore the eigenvalues of ##S_z## are no longer good quantum numbers and we can't really separate the effect of eigenstate with ##S_z = \hbar/2## and that with ##S_z=-\hbar/2##. It can be shown that when the spin orbit effect becomes important, one of the good quantum numbers are those corresponding to the total angular momentum operator ##\mathbf{J}=\mathbf{L}+\mathbf{S}##.
Ok, but aren't the results of the stern-gerlach experiment due to the positive or negative spin of the outer valence electron? And if so, wouldn't the electron orbitals differ depending on the sign of the spin?
The electron configuration for silver atom is [Kr]4d10 5s1, as you said it has one valence electron in s shell, so the total orbital angular momentum is zero and the total spin angular momentum is 1/2. This makes the total angular momentum ##J=S## and consequently ##m_j=m_s## - the fact that the total orbital angular momentum ##L## is zero makes its effect on the total angular momentum ##J## not apparent and this one is completely governed by ##S##. However if a silver atom is free of any perturbation, the energy levels are degenerate in ##m_j##. So now answering your question,
it really depends on the system, if the Ag atom is isolated its orbital won't be effected by the sign of the z component of the spin. However, as pointed out in comment #2, if there is external magnetic field, the energy levels are no longer degenerate in ##m_j##'s, rather it will split into different energy levels.
1. What is electron spin in an atom?
Electron spin is a fundamental property of an electron that describes its angular momentum and orientation in space. It is one of the four quantum numbers used to describe an electron's energy state in an atom.
2. How is electron spin related to magnetism?
Electron spin is the basis for magnetism in atoms. The spinning motion of electrons creates a tiny magnetic field, which can interact with other magnetic fields to create the macroscopic magnetism we observe in objects.
3. Can electron spin change?
Yes, electron spin can change through interactions with other particles or fields. For example, when an electron is excited to a higher energy level, its spin can change. In addition, certain particles, such as photons, can flip the spin of an electron.
4. How is electron spin measured?
Electron spin can be measured using a technique called electron spin resonance (ESR). This involves applying a magnetic field to a sample and observing how the electrons interact with the field, which can reveal information about their spin.
5. What is the significance of electron spin in chemistry and physics?
Electron spin plays a crucial role in both chemistry and physics. In chemistry, it determines the magnetic properties of molecules and can affect chemical reactions. In physics, it is important for understanding quantum mechanics and the behavior of particles in magnetic fields.
  • Quantum Physics
  • Quantum Physics
