Finding the Magnetic Field Gradient for the Stern Gerlach Experiment
The discussion focuses on calculating the magnetic field gradient required for the Stern-Gerlach experiment, where silver atoms are deflected in an inhomogeneous magnetic field. The force on a magnetic moment in this context is expressed as F(z) = u(z) * (dB/dz). The participants clarify that the gravitational force can be ignored as it affects both spins equally, emphasizing that the separation of spins arises from the field gradient. To determine the z-component of velocity after traversing a 1-meter distance, the relationship between force, magnetic moment, and the field gradient is essential. The conversation concludes with a suggestion to approach the problem using kinematics based on the derived equations.
Benzoate
the force on a magnetic moment with z component u(z) moving in an inhomogenous magnetic field is given by Equation 7-51: F(z)=u(z)*(dB/dz). If the silver atoms in the stern gerlach experiment traveled horizontally 1 meter through the magnet and 1 meter in a field free region at a speed of 250 meters/second, what must have been the gradient of B(z) , dB(z)/dz, in order that the beams each be deflected a maximum of .5mm from the central , or no field, position?
F(z)=u(z)(dB/dz)
u(z)=-m(Ag)*u(B)
u(B)=9.27e-24 Joules/tesla
v=250m/s
x=1 meter
distance in field free region=1m
U=u(z)*B
F(z)=u(z)*(dB/dz)=> m(Ag)*gravity=-m(Ag)*u(B)*dB/dz.
masses cancel , so I'm left with::
gravity=-u(B)*dB/dz
-gravity/u(B)=dB/dz
to find B(z), I apply the equation U=u(z)*B. U=mgh and I alrealdy know what u(z) is equal to from the first part of the problem. THEREFORE, mgh/u(z)=B(z) . I don't know what relevancy the velocity and the deflected maximum distance served in finding B(z) and dB(z)/dz
Will someone please help me?
First of all, ignore gravity - it is small and it affects both spins identically.
The separation between the spin up and spin down atoms comes from the force due to the field gradient. This force is oppositely directed for the oppositely oriented moments. Since you know that the force is proportional to the field gradient, which exists over a region that is 1m long, you can find the z-component of the velocity after this 1m has been traversed (the initial z-component of velocity is 0), in terms of dB/dz and the magnetic moment (don't forget the Lande' g-factor). From here it's a kinematics problem.
Did that help?
