Exploring Energy Levels and Electron Configurations in Atomic Models
In summary, the atomic configuration follows a pattern where each shell contains a certain number of sub-shells denoted by the letters s, p, d, and f. These sub-shells have a specific number of electrons, with the s sub-shell having 2, the p sub-shell having 6, the d sub-shell having 10, and the f sub-shell having 14 electrons. This explains why each shell can only hold a certain number of electrons, with the K shell having 2, the L shell having 8, the M shell having 18, and the N shell having 32 electrons. Furthermore, electrons in the outermost layer require less energy to be removed, which explains why the last layer has more energy
scientifico
181
Hello, why in the normal atomic configuration every layer except the second can contain only up to 8 electrons if for example the level with quantic number 3 contain up to 18 electrons?
What relation is there between this two models?
Thank you!
You have the K,L,M,N (and so on) shells, which contain 2,8,18,32.. electrons.
Those numbers come from the sub-shells which make up the shells, which are denoted s,p,d,f.
The sub-shells contain 2, 6, 10, 14 electrons, respectively. (twice the odd numbers 1,3,5,7)
The K shell contains only an s sub-shell, so it has two electrons in total. The L shell has one s and one p, giving 2+6=8 electrons in total.
The M shell has an s,p and d, so 2+6+10 = 18, and the N shell has an f sub-shell as well, so 2+6+10+14 = 32 electrons.
An electron in the last layer require less energy to be removed, so why the last layer has more energy than the layer nearest the nucleum?
What is electronic configuration?
Electronic configuration is a representation of the distribution of electrons in an atom or molecule. It describes the arrangement of electrons in energy levels and sublevels within the atom.
Why is electronic configuration important?
Electronic configuration is important because it determines the chemical and physical properties of an element. It also helps to predict an element's reactivity, bonding capabilities, and stability.
How is electronic configuration determined?
The electronic configuration of an atom is determined by the number of electrons in each sublevel, which depends on the atomic number of the element. The electrons fill up the sublevels in a specific order, known as the Aufbau principle.
What is the purpose of writing electronic configuration in shorthand notation?
Shorthand notation for electronic configuration is used to simplify the representation of the distribution of electrons. It involves using noble gas notation, where the symbol of the noble gas in the previous period is written in brackets, followed by the remaining electrons in the outermost energy level.
What are valence electrons and how are they related to electronic configuration?
Valence electrons are the electrons in the outermost energy level of an atom. They are related to electronic configuration because they determine the chemical and physical properties of an element, and their number and distribution can be predicted from the electronic configuration of an atom.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
