Electron Movement: Reasons for Revolution Around Atom
  • Thread starter Thread starter Seniour Baloc
    Movement
The discussion centers on the nature of electron behavior around atoms, emphasizing that electrons do not revolve around the nucleus as previously thought in early atomic models like Bohr's. Instead, the electrostatic force of attraction holds electrons within the atom but does not cause their movement. Classical physics fails to adequately describe atomic stability, as electrons in circular orbits would lose energy and spiral into the nucleus. Quantum mechanics, particularly through the Schrödinger Equation, provides a more accurate framework, introducing the concept of wavefunctions. This approach illustrates that electrons occupy a volume of space around the nucleus, leading to the use of "orbitals" rather than orbits, and explains the stability of atoms without the issues posed by classical theories. The discussion highlights the importance of quantum mechanics in understanding atomic structure and behavior.
Seniour Baloc
What is the reason for revolution of electrons around the Atom?
Chemistry news on Phys.org
the reason is electrostatic force of attraction.
u need to check quantum physics and the theories B4 that to actually start imagining.
Electrons don't revolve around the atom. In the early atom models (Bohr) they were assumed to revolve around nucleus. But we know it is not true for almost 90 years.
Electrostatic force could only hold them within the atom but don't cause their revolutionary movement.
First, they don't revolve, so it doesn't matter.
Second, you are wrong - in classical systems electrostatic forces would work just like gravitation does in the planetary system. Gravitation is the only real force that is present in planetary systems, and in such systems planets do revolve around the central body.
If one describes atoms using only the Coulomb forces, the electron and the nucleus will attract each other and no stable atoms could exist. Obviously this is not the case. Niels Bohr was the first (1913) to propose a better model, which consisted of electrons moving around the nucleus in circular orbits. Each orbit corresponds to a certain discrete energy level. This model is based upon the quantisation of the angular momentum.
Unfortunately, electrons moving in a circular orbit have an acceleration due to the centripetal force. In classical electromagnetic theory, an accelerated charged particle must emit EM-radiation due to energy conservation. Hence, the electron would lose energy and spiral down towards the nucleus. Again stable atoms could not exist. What is wrong now?
It turns out that the picture of electrons moving in circular orbits around the nucleus isn’t correct either(*). The solution here is the implementation of Quantum Mechanics via the Schrödinger Equation and the concept of wavefunction. By applying such formalism, the “electron” occupies a volume of space simultaneously, so that it is “smeared” in a particular geometry around the nucleus. While there are no more “orbits”, we do use the term “orbitals” to indicate the shape of such geometry. However, this term should not be confused to mean an orbiting electron similar to our planets in the solar system. By describing the system in terms of the QM wavefunction, it creates stable states for the nucleus+electrons system that matches very well with experimental observation of standard atomic spectra.
Since there are no more “orbits” in the conventional sense, the problem of electrons radiating due to an accelerated motion is no longer meaningful. It explains why we have stable atoms.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
