What is the Electric Field Near a Small Hole in a Charged Spherical Shell?
wakko101
The question : Consider a thin spherical shell of radius R with a uniform charge density sigma. If a very small piece of this surface were removed, leaving a small hole, what would the electric field be at a point just above/below the hole?
Relevent info : the field due to the patch of surface (when intact) is the same as that of an infinite plane just below and above the surface (because if you're just above or below, the essentially flat surface looks like an infinite plane).
Does this mean that the field just above and below the surface is due solely to the patch itself, in which case the field would be 0? Or must one still take into account any contribution from all other points. Then again...if we're thinking about the points just above and below, would the leftover contributions be essentially perpendicular to the surface, in which case, it is 0 again? Did that even make sense?
This problem is confusing me, any hints/advice would be appreciated.
Cheers,
W. =)
Try thinking of the hole as a point charge of the opposite charge...
This is an old classic problem.
When the surface is whole, the field on one side is E, the field on the other side is zero.
Using symmetry, tells you that E/2 is due to the small piece.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
