Electrowetting simulation problem
  • Thread starter Thread starter HellRaiZer
    Simulation
The discussion focuses on solving an electrowetting problem using the finite element Galerkin method, specifically determining the shape of a liquid drop and the potential distribution in the electrode and air. The user has calculated residuals for potential in both air and electrode, as well as for the free surface and volume constraint of the liquid drop. The main issue arises in calculating the derivatives of the potential residual in air with respect to the free surface variables. The user seeks suggestions on how to address this derivative calculation challenge. The thread emphasizes the complexity of the mathematical modeling involved in electrowetting simulations.
HellRaiZer
Hi,
I'm trying to solve an electrowetting problem, by using the finite element Galerkin method. The problem is to find simultaneously the shape of the liquid drop and the distribution of potential in electrode and air.
I've calculated the residuals for the potential u (Ru), in both air (Ru2) and electrode (Ru1) (as seen in the figure inside the attachement) as well as the derivatives with respect to uj (for the jacobian). I also have calculated the free surface (f(θ)) residuals (Rf), and their derivatives with respect to fj. Finally i have calculated the volume constraint residual (Rv) for the liquid drop, and its derivatives with respect to f.
I'm having a problem calculating the derivatives of Ru2 with respect to fj.
Ιn the attachment you can find all the equations i mentioned earlier. And the actual question (in the third page).
Do you have any suggestion on how this can be done ?
Thanks in advance.
HellRaiZer.
P.S. If this is the wrong forum please move it to the correct one.
ping @BvU . Can you help with this spring cleaning post?
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
