Elementary Differential equations : seperable making it explicit
Mdhiggenz
(y+2)dx +y(x+4)dy=0
∫(1/x+4)dx + ∫(y/y+2)dy=0
ln(x+4)-2ln(y+2)+y=lnc
Here is where I get confused how do I make this into an explicit solution,
that +y really bothers me.
I was thinking ln [ (x+4)/(y+2)^2] +y = lnc
raising both sides to e^x
(x+4)/(y+2)^2+e^y=c
but the answer is
x+4 = [(y+2)^2]*e^(-y+1)
(x+4)/(y+2)^2+e^y=c
That's not correct. When you raise both the sides to e, you get this:
e^{\ln((x+4)/(y+2)^2)+y}=c
which is equal to
\frac{x+4}{(y+2)^2} \cdot e^y=c
And can you check the answer you posted? I get (-y+c) instead of (-y+1).
They hold that the answer is -y+c. I forgot to mention that it is a boundary problem y(-3)=-1
Would that have anything to do with it?
Also from what you got I do not quite understand how you got -y+c
if you multiply both sides by [(y+2)^2]/e^y
wouldnt it be x+4= c(y+2)^2/e^y ?
Yep, it would be that, but 1/e^y=e^(-y).
c is a arbitrary constant, that is we can write it like this, e^c which is again a constant or we can even write it as ln(c) which is also equal to a constant. To get the answer you posted, i wrote c as e^c.
Excellent, I appreciate your help on these problems.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
