Eliminating x in Lorentz Transformation
The discussion focuses on the elimination of x from the Lorentz transformation equations, specifically how to derive the time transformation formula. The user initially attempted to substitute x into the x' equation but made an error in their final expression for t. Another participant corrected this by providing the accurate formula for t, which involves the Lorentz factor (gamma) and the relationship between x' and t'. The derivation shows that t can be expressed as a function of t' and x', incorporating the effects of velocity. The user ultimately expresses gratitude for the clarification and confirms their understanding.
ZedCar
At the bottom of this page:
http://www.cv.nrao.edu/course/astr534/LorentzTransform.html
It states;
Lorentz factor:
x=y(x'+vt') and x'=y(x−vt)
Eliminating x from this pair of equations yields
t=y(t'+vx'/c^2)
* y =gamma
How did they eliminate x?
I'm taking the x value which is y(x'+vt') and substituting this into the x value in the x' equation.
So I'm getting;
x' = y^2(x'+vt')-yvt
Then I've separated the equation so that t is on LHS;
t = [y^2(x' + vt')] / yv
If anyone knows how this is done, I'd be very interested in learning! Thank you. :smile:
Your last expression is wrong, it should be:
t = \frac{(\gamma^2 - 1)x^\prime + \gamma^2 vt^\prime }{\gamma v}
Now:
\gamma^2 = \frac{1}{1-v^2/c^2}
= \frac{c^2}{c^2 - v^2}
so that:
\gamma^2 - 1 = \frac{c^2}{c^2 - v^2} - \frac{c^2 - v^2}{c^2 - v^2}
= \frac{v^2}{c^2 - v^2} = v^2 \frac{\gamma^2}{c^2}
Therefore, the above expression becomes:
t = \frac{v^2\gamma^2 x^\prime}{\gamma vc^2} + \frac{\gamma^2 vt^\prime}{\gamma v}
= \frac{\gamma v x^\prime}{c^2} + \gamma t^\prime
= \gamma(t^\prime + vx^\prime / c^2)
Cheers very much for that.
I understand it now!
Thank you :smile:
