Elliptical Equation of a Spotlight
  • Thread starter Thread starter jarate_master
The problem involves finding the elliptical equation for a spotlight beam hitting the stage floor at a 60-degree angle. The diameter of the beam is 25 cm, leading to a shorter axis of 12.5 cm, calculated using the cosine of the angle. The longer axis can be determined using trigonometry, specifically by applying the right triangle relationship at the point where the beam meets the floor. The final equation for the elliptical pool of light is (x^2/208.3) + (y^2/156.3) = 1. This solution highlights the importance of understanding the relationship between the dimensions of the beam and the geometry involved.
jarate_master
I've pretty much given up on this problem:
"A spotlight throws a beam of light that is 25 cm in diameter. If the beam hits the stage floor at an angle of 60 degrees with the horizontal, find an equation for the elliptical pool of light on the stage floor. (Figure 2-23)"
http://books.google.com/books?id=4lwuyKlK6FsC&lpg=PA50&ots=cJyn8pzoNu&dq=33&pg=PA50" at Google books.
The answer is (x^2/208.3) + (y^2/156.3) = 1 (all odd-numbered questions have answers provided in the back). It doesn't show any work, however.
The equation for an ellipse:
(x^2/a^2) + (y^2/b^2) = 1
Equation for circle:
x^2 + y^2 = a^2
Pythagorean Theorem
a^2 = b^2 + c^2
I tried
25*cos (60) = 12.5
to attempt to find the length of the y-axis above the horizontal. This is correct according to the back of the book as
12.5^2 = 156.25.
But now I'm stuck.
You got the wrong number right by accident. The a and b in your equation are like 'radii' not 'diameters'. 156.25=(25/2)^2=(12.5)^2 which is the axis that doesn't get multiplied by any trig function. Because it doesn't change. What's the longer one?
I agree that the attempted solution should be incorrect because of what you described, but it got the "magic number" (which could have been deduced more properly by theorizing that one axis stays the same length as the diameter of the beam of light). This brings me back to the same question ; it seems (to me at least) there isn't enough information to find the length of the larger axis.
Sure there is. At the point where the 'back' of the beam hits the floor (the one closest to the light) draw a diameter across the beam. That's perpendicular to the beam so it makes one leg of a right triangle with length 25 cm with the length you are looking for being the hypotenuse. Find an angle and use trig.
1/cos (30) = x/25
x/2 = 14.43
Substitute for a in the equation
which is the answer. Thanks :biggrin:.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
