Calculating Eccentricity for an Elliptical Orbit
To calculate the eccentricity of a satellite's elliptical orbit around a planet with a mass of 4 x 10^20 kg, the relevant equations include mechanical energy conservation (ME = KE + PE), where kinetic energy (KE) is derived from the satellite's velocity and potential energy (PE) is based on gravitational attraction. The satellite is positioned at a distance of 10^7 m and has a velocity of 40 m/s at a 30-degree angle, leading to a vertical velocity component. The eccentricity can be determined using the relationship between eccentricity, semi-major axis, and semi-latus rectum. Despite initial calculations, the correct eccentricity is found to be 0.89. Understanding these relationships is crucial for solving similar orbital mechanics problems.
superaznnerd
a satellite is set to orbit a planet of mass 4X 10^20 kg .
It is placed at a distance of separation of 10^7m with a velocity of 30 degrees to the line connecting the center of the planet and the satellite. What will be its eccentrity fo orbit? (Answer is .89)
ME = KE + PE
KE = 1/2 mv^2
PE = -GMm/r
I did 40m/s *sin (30) = vertical velocity.
Then, I plugged it into the equation -GMm/r = .5m(40m/s *sin (30))^2 + -GMm/r
I didn't get the answer though...
please help!
help please
You may want to think (or read in your textbook) about how eccentricity (e) is related to the semi-major axis (a) and semi-latus rectum (p), and how those two again are related to the information you were given in the problem text.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
