What is the tension in the cord as the elevator accelerates?
  • Thread starter Thread starter runner1738
    Tension
The discussion focuses on calculating the tension in a cord holding a 9.8 kg bundle in an accelerating elevator. The elevator accelerates upward, and the tension must account for both gravitational force and the elevator's acceleration. The correct formula for tension is T = m(g + a), where 'a' is the elevator's acceleration derived from its movement over time. The acceleration is calculated using the equation xf = xi + vi + 1/2 at^2, leading to a final tension value of approximately 104.75 N. It is emphasized that if the elevator were descending, the acceleration would be subtracted from gravity.
runner1738
elevator tension problem
An elevator starts from rest with a constant upward acceleration and moves 1 m in teh first 1.5s. A passenger in the elevator is holding a 9.8 kg is holding a 9.8 kg bundle at the end of a vertical cord. G=9.8 m/s^2. What is the tension in the cord as teh elevator accelerates? Answers in units of N.
my work: (9.8kg * g)((4/9 m/s^2)/g + 1) = 96.04(1.045351474)=100.39555556 the 4/9 is the acceleration in the y direction 1/1.5/1.5 so m/s^2 right? this wasnt right what is wrong?
t=MAy+ mg? so I am guessing the thing i have wrong is acceleration right?
the answer was 104.751 someone said a=v^2/2d then use a in ma+mg but that never gave me 104.751 unless i just can't add, anyone?
well first you need to find the acceleration of the elevator
xf=xi + vi + 1/2 at2
1m=0 + 0 + .5a(1.5)2 so a= 1m/(.5 x 2.25s2)
this will be vectorally added with the acceleration due to gravity
then tension will be equal to the weight T=weight=m(g+a)
T=9.8kg x (9.8 m/s2 + 1m/.5 x 2.25s2)
that'll give you exactly 104.7511111 N
just remember in these cases, the elevators acceleration just adds to gravity
if the elevator was heading down you need to subtract it
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
