EM , magnetic field at centre of a carrying circular loop
The discussion focuses on calculating the magnetic field at the center of a current-carrying circular loop using both Biot-Savart Law and Ampere's Law. The Biot-Savart Law yields a magnetic field of B = (μ₀I)/(2R), while the attempt with Ampere's Law leads to a different result of B = (μ₀I)/(2πR). Participants clarify that Ampere's Law is not applicable in this scenario due to the lack of symmetry in a single loop, which prevents B•dl from being constant. It is emphasized that Ampere's Law is effective in cases with symmetrical configurations, such as infinite wires or solenoids. The conversation concludes with a suggestion to derive Biot-Savart Law from Ampere's Law for further practice.
binbagsss
The question is to find the magnetic field at the centre of a current carrying circular loop of radius R, where the current = I
Okay so I'm trying to do this by both Amp's Law and Biot Savarts Law, and I can't get my answers to agree.
First method - Biot Savarts Law:
B=\frac{I\mu_{0}}{4\pi}\int\frac{dl X \hat{n}}{n^{2}}
n^{2}=R^{2}
dlX\hat{n}=dl (as |n|=R is always perpendicular to a given line element dl)
=> B=\frac{I\mu_{0}}{4\pi}\int\frac{dl X \hat{n}}{n^{2}}=\frac{I\mu_{0}}{4R^{2}\pi}\intdl=\frac{I\mu_{0}}{4R^{2}\pi}2R\pi=\frac{\mu_{0}I}{2R}
Second method - Ampere's Law:
\ointB.dl=\mu_{0}I(enclosed)
So B\ointdl=\mu_{0}I
B2\piR=\mu_{0}I
=> B=\frac{\mu_{0}I}{2πR}
Thanks in advance.
In your Ampere's Law attempt, what is the loop you are using to determine the line integral? How did you arrive at 2\pi R in the third line?
An amperian loop running over the circular loop of wire
Ampère's law only applies in magnetostatics. That is, \vec{B}\cdot d\vec{l} must be constant for all d\vec{l} in the loop. Is that the case for your ampèrian loop?
Oh okay, because I constantly changes direction so does the direction of the magnetic field, although its magnitude is equal, and so B can not be taken outside the integral in line 3 of original post. Am I correct in thinking it is not possible to find any amperian loop were B.dl is constant?
Correct. Ampere's Law can only be applied when B•dl is constant along the entire loop. It can be used for situations such as an infinitely long wire or solenoid because symmetry ensures that B is constant. There is no such symmetry in a single loop, so that's why Ampere's law isn't useful in this case.
yeah. also, you can derive the Biot-Savart law from Ampere's law, if you want some practice at integration.
