What is an EM wave composed of?
In summary, EM waves are composed of alternating electric and magnetic field vectors. They propagate through space or a medium, and can generate electric pressure waves.
EEngineer91
38
Hi,
I have a few question about EM waves. What is an EM wave composed of? Are the E and B field lines real or imaginary. .. if it is an wave what is waving? (Eg water is waving in tsunami)
wouldn't a pulsating chargr produce a electric pressure wave?
An EM wave is composed of alternating electric and magnetic field vectors. That is, the direction and magnitude of the electric and magnetic fields are fluctuating and changing direction over time. Note that field lines are not "real" objects but merely a way of helping us visualize the fields. They are like the contour lines that show you the elevation of terrain on a map.
I don't know what an electric pressure wave is. An AC or pulsating DC voltage source with generate EM waves within the circuit it is connected to.
The lines of force are just a way of representing the fields. An EM wave is 'composed of' varying E and B fields which propagate through space or a medium. The name "wave" tells you that EM waves share a number of characteristics with other, visible mechanical waves. In the case of EM waves, nothing actually needs to wave about, though. No movement is involved with waves moving through empty space but charged particles are sometimes measurably displaced as an EM wave moves through a 'medium'.
I'm not sure what sort of "pulsating Charger" you mean but when you switch an electric current on and off, an EM pulse will radiate out into space. You may have heard 'click' interference on a radio when a heater is switched on and off and everyone will have heard the sort of interference that old car ignition systems can cause on weak radio signals.
So EM waves (real) are composed of things we do not consider real (E and B induction)?
An electric pressure wave is the same as an air pressure wave...a non - transverse wave
That's my point...they need a medium to propagate...the virtual photon flux field...or quantum vacuum
Of course we consider them as "real". Reality doesn't have to involve mechanical movement.
I don't know what you mean by "Electrical Pressure Wave". What is the context of that term? Are you referring to piezo electric distortion?
I think you need to describe your level of actual knowledge of this topic. Do you know what a virtual photon flux field is? You may just be trying to jump too far in one go.
Imagine an air pressure wave...now replace the air with E and B field lines...a electro pressure waave...with longiudinal propagatiion
Yes, I have a bachelors degree in physics thanks
So you will know about Maxwell's equations and the solution which gives a propagating EM wave? The fields are transverse for a plane wave. In situations near a conducting structure (tied waves etc) the field may be longitudinal.
The situation with a mechanical pressure wave is very different, that can be longitudinal or transverse and it is risky to try to draw too many conclusions about EM waves from what you know about mechanical waves.
You have confused me because you have used a term "quantum vacuum" yet you seem to be wanting a very mechanical model for your EM waves.
Well, maxwell equations give no longitudinal waves only in free, empty space. Empirically, space is not free or empty but prevaded by a sea of virual photons popping in and out of existence
So you want an Advanced Physics discussion but using mechanical models? You can have one or the other but not both, I think.
Im sorry you think those two concepts are mutually exclusive...the fact is they must be interrelated
This can occur in conductors where there are charges that are able to move in response to the applied fields, but there is no such thing in free space. EM waves in free space are transverse waves.
So what would be changed in our understanding of EM waves if scalar longitudinal waves existed in some virtual medium?
Well, our understanding would go beyond standard theory and you could produce non-linear effects. ..propagation of em waves relates to velocity of light...all this could not apply to non-transverse waves since photons are only transverse...and like I said for empty space derivation there is no such thing as free (empty) space so these derivations are a limiting and special case...you claim these field lines have no reality but em waves do...this is not consistent
I can't even understand what you're trying to get at. It appears to make absolutely no sense.
Also, field lines are visual representations of what the field is doing. They allow us to visualize the force that the field will apply to charged particles. That's all they do. The wave itself does not consist of field lines.
I think it's time you provided some reference or experimental evidence for your opinion here. (It is not textbook stuff). That is what us needed for PF. Opinions are not really accepted without some backup. Read the forum rules.
So are you saying these waves could transmit information at FTL speeds or counter the laws of thermodynamics and relativity?
I simply ask what is waving in an em wave...I hear its field lines but these are not real but em waves are lol
Velocities would not apply to these "waves"...they are non electromagnetic...light constant is directly related to permittivity and permeability of free space...which is not empty but is considered so when doing theorectial calculations...not correct completely
Personal theories are not allowed. Thread closed.
Related to What is an EM wave composed of?
1. What are the components of an EM wave?
An electromagnetic (EM) wave is composed of two components: an electric field and a magnetic field. These fields are perpendicular to each other and oscillate in a direction perpendicular to the direction of propagation of the wave.
2. How do the electric and magnetic fields interact in an EM wave?
The electric and magnetic fields in an EM wave are not separate entities, but rather are intertwined and work together to propagate the wave. As the electric field changes, it creates a changing magnetic field, and vice versa. This creates a self-sustaining wave that can travel through space.
3. What is the role of wavelength in an EM wave?
Wavelength is the distance between two consecutive points on an EM wave that are in phase, meaning they have the same amplitude and are at the same point in their oscillation. The wavelength of an EM wave determines its frequency and energy, with shorter wavelengths corresponding to higher frequencies and more energy.
4. Can EM waves travel through a vacuum?
Yes, EM waves can travel through a vacuum, which is the absence of any material medium. This is because they do not require a medium to propagate, unlike mechanical waves, which require a medium such as air or water.
5. How are EM waves produced?
EM waves are produced by accelerating charged particles, such as electrons, in an antenna or other source. This acceleration creates changing electric and magnetic fields, which then radiate outwards as an EM wave. EM waves are also produced by the natural oscillations of charged particles, such as in the sun and other stars.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
