Calculating Velocity in a Sticky Situation
  • Thread starter Thread starter FancyNut
The discussion revolves around calculating the velocity of a ball as it exits a sticky section, where it enters with a velocity of 4 m/s. Participants clarify that the motion can be understood conceptually rather than through equations, emphasizing the importance of analyzing the distance between motion diagram dots. The ball leaves the sticky area with half its initial velocity, resulting in a final speed of 2 m/s, as indicated by the spacing of the dots. Additionally, it is noted that once the ball exits the sticky part, there is no acceleration, confirmed by the equal spacing of the dots. This understanding aids in grasping similar problems in the future.
FancyNut
Ok I don't have time to look at this problem for more then I already have... Help would put my (little) brain at ease...
What is the velocity of the ball as it leaves the "sticky" part? It enters it with 4 m/s (and I'm sure that's correct) and the film of the ball is made at two frames per second... so that's just one second from the beginning to the end of the sticky section.
I have the time and initial velocity but with no acceleration I don't know how. =\
*hides*
this is just a simple motion diagram, so hence
you don't need any values to figure it out. it is totally conceptual. just look at the distance between the dots after the sticky part and you know the time in between those dots.
hope this helps.
So it leaves the sticky part with HALF the velocity it entered with? I'm just guessing here from the distance between the balls after the sticky part and before...
*enters 2*
It's correct. heh.
Man I went crazy thinking of how to do this with an equation. I hope someone doesnt' post after me going "yes there is an equation actually." :smile:
Thanks. :)
well here, since you got the problem right already i'll try to explain it better for you, so you understand it and will be able to get it easily the next time you encounter a question like it.
It says that each dot is 0.5s apart(2 frames/second)
so if you see that the distance between the dots is 1m as it comes off of the sticky part in order to get velocity, 1m/0.5s = 2m/s.
You can also tell that once it leaves the sticky part there is no more acceleration, because the dots are equally spaced apart, so that means that their velocities are equal.
Thanks again. :smile:
