Endothermic / exothermic reaction
Compounds that are soluble in water and can create a cooling effect through endothermic reactions include ammonium nitrate, commonly used in cold packs. While this compound effectively cools water upon dissolution, it is important to note that it is not considered safe for ingestion. The discussion emphasizes the need for caution when considering any chemical for consumption, even if the intent is purely theoretical. Further research is encouraged to explore additional compounds, but safety remains a primary concern.
hamudi786
Hello,
I need a few compounds that i can use that are soluble with water that causes the water to cool, so that if ingested it will not do any harm. your advice would be greatly appreciated, also if you may include a chemical formula if it is known. THANK YOU.
P.S. this is out of interest. no ingestion will occur LOL
Chemistry news on Phys.org
hamudi786 said:
Hello,
Dissolution of solid ammonium nitrate is a classic example of an endothermic process (I think that is how those one-time break-seal cold packs work). There are other examples, but this should be enough to get you started with a google search. None of them should ever be considered "safe for ingestion", in my opinion.
It seems like a simple enough question: what is the solubility of epsom salt in water at 20°C? A graph or table showing how it varies with temperature would be a bonus. But upon searching the internet I have been unable to determine this with confidence. Wikipedia gives the value of 113g/100ml. But other sources disagree and I can't find a definitive source for the information. I even asked chatgpt but it couldn't be sure either. I thought, naively, that this would be easy to look up without...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
