Endurance limit / fatigue strength at high temperatures
At high temperatures, material properties such as tensile strength, yield strength, and modulus of elasticity decrease, which also affects fatigue strength. Fatigue strength becomes time-dependent due to transformations in material structure caused by processes like diffusion, aging, and recrystallization. These processes facilitate easier plastic deformation, leading to creep, which is the continued plastic deformation under sustained load. Increased plastic deformation in the plastic zone of fatigue cracks can enhance fatigue damage accumulation. Consequently, understanding these relationships is crucial for predicting material behavior under high-temperature conditions.
kajalschopra
Hello All,
I had been reading a book on Machine Design.
I understand that at high temperatures, yield strength of the material drops. The behaviour of the fatigue strength i.e. the drop in fatigue strength may at times be taken to be of same proportion as that of yield strength.
It is also said that at high temperatures, the fatigue strength gets dependent on time.
I do not understand that why fatigue strength is a function of time?
Thanks
Kajal
Science news on Phys.org
"Material properties are dependent on the temperature. The tensile strength, yield strength and modules of elasticity decrease with increasing temperature. It should be expected that fatigue properties are also affected by the temperature. The effect of a high temperature on mechanical properties can be associated with [time dependent, ed. by LJ] transformations of the material structure due to diffusion processes, aging, dislocation restructuring (softening), and recrystallization. In general, such processes imply that plastic deformation can occur more easily at an elevated temperature. This can lead to the well-known creep phenomenon defined as continued plastic deformation under sustained load. With respect to fatigue, it can imply that more plastic deformation and creep occur in the plastic zone of a fatigue crack which may apply to both microcracks and macrocracks. As a result, fatigue damage accumulation might be enhanced. Furthermore, other failure mechanisms are possible. During creep under sustained load, creep failures occur by grain boundary sliding, void formation (also often at grain boundaries), void growth and coalescence."
from: (2009) High-Temperature and Low-Temperature Fatigue. In: Schijve J. (eds) Fatigue of Structures and Materials. Springer, Dordrecht
With respect to creep: https://en.wikipedia.org/wiki/Creep_(deformation)
Likes kajalschopra
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
