How many meters does the spring compress?
  • Thread starter Thread starter linnus
    Spring
To determine how many meters the spring compresses, first apply conservation of momentum to find the velocity of the block after the projectile embeds itself. The initial momentum of the system is equal to the momentum of the combined block and projectile immediately after the collision. Next, calculate the kinetic energy of the block and projectile system using the combined mass and the velocity obtained. Finally, use the potential energy formula for the spring to find the compression distance. This step-by-step approach effectively accounts for the inelastic nature of the collision and energy conservation principles.
linnus
A 10.5 kg block, attached to the left end of a horizontal massless spring, sits on a frictionless table. The right end of the spring is attached to a vertical piece of wood that is firmly nailed to the table. A 0.0500 kg projectile is fired, from left to right, into the block at 85.5 m/s and stops inside it (this is a completely inelastic collision). The spring constant is k = 105 N/m. How many meters does the spring compress? The potential energy due to the compression of the spring can be calculated with the following formula: PE = (1/2)kx^2.
1/2mv^2
1/2kx^2
momentum before=momentum after
uh...
Why can't you do...
1/2mv^2=1/2kx^2?
x=1.866...which isn't right
Break down the problem into 2 steps. The bullet is going to become embedded in the block. For inelastic collisions, energy conservation is generally not useful because some of the kinetic energy of the bullet is dissipated by friction or turned into heat, and neither of these are easy to calculate. Therefore, use conservation of momentum to calculate the velocity of the block with the bullet embedded in it IMMEDIATELY after the bullet is embedded (ignore the spring for now). Then, when you have that velocity, you can calculate the kinetic energy of the block/bullet (sum the masses also, do you see why?) combo and then use energy conservation to solve for the compression of the spring.
