Energy Density of a Charged Sphere?
The discussion revolves around calculating the fraction of total energy stored in a charged plastic sphere from the center to half its radius. The initial approach involved using the ratio of energy densities, leading to a conclusion of (1/8)E0. However, it was recognized that the electric field within the sphere varies with radius, which complicates the calculation. The participant acknowledged missing key equations related to the electric field's dependence on radius, impacting their solution's accuracy. The conversation highlights the importance of understanding how electric fields behave in charged spheres for accurate energy calculations.
xxacefirexx
Since this was on the test, I won't be able to type out the question verbatim, but here it goes:
You have a plastic sphere with charge equally distributed through out the sphere. The radius of the sphere is a. The energy stored in the total sphere is E0 (not to be confused with electric field). Find the fraction of the total energy from r=0 to r=a/2 (half the radius).
energydensity*volume = energy
I simply put a ratio of the two energies, so E(small)/E0. Since charge is equally spread throughout the sphere, I figured that the energy densities would cancel out, leaving the volume(small)/volume(big). Dividing out gives (1/8)E0.
However, this seems unreasonably easy, and I think I'm missing something very important. Did I do it correctly, or am I forgetting something?
yes it does...
so it looks like i assumed that because the charge is constant, that the electric field is constant, which is not the case.
I missed 2 big equations in that, so looks like I am not even going to get that much partial credit :frown:
at least now i can sleep knowing the answer. btw, that's an excellent site.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
