Energy from White Dwarf Thermonuclear Runaway
kvl214
Hello!
The question is "Calculate the energy released if a 1 solar mass white dwarf undergoes a thermonuclear runaway and converts 0.5 solar mass of carbon (A=12) to iron (A=56)."
I've only ever done nuclear equations with hydrogen fusion, with four hydrogens to one helium. But I don't know the reaction for carbon to iron, since it's not evenly divisible.
rest mass energy E = mc^2
energy released = E(reactants) - E(products)
I calculated the number of carbon particles from 0.5 solar masses -- 7.4e56 C particles
And the rest mass energies of carbon and iron -- C=1.1e4 MeV, Fe=5.2e4 MeV
Since 56/12 = 4.66, do we just use a fraction amount for carbon? So 4.66 C → 1 Fe ?
I just don't know where to go from here.
Any help would be greatly appreciated! Thanks
Nuclear reactions tend to operate slightly differently than chemical reactions.
Haven't you studied other nuclear reactions which occur in stars?
We only did hydrogen fusion, nothing with heavier elements...
What would you do for nuclear reactions?
Thanks!
I recalculated the rest mass energies with the atomic masses, since before i just used the integer number. So if i subtract 4.66*carbon energy from iron energy, does that work for the energy released in one reaction?
I also calculated that there are 1.6e56 reactions available from the mass of carbon...
I don't think you can take the 56/12 ratio to determine the quantity of iron produced. The nucleon count won't be preserved. Rather, reactions involve integral numbers of atoms. Of course, there are different pathways, but if the whole process only uses one pathway then there must be a whole number of carbon atoms to one iron atom.
That's not right. You are thinking of chemistry. I think the only reasonable way to interpret the question is preserving the nucleon count. All you need to know about the reaction is that each nucleon will eventually wind up in an iron nucleus. So just find the mass per nucleon in carbon and use that to find the initial number of nucleons. Then find the mass difference between a nucleon in carbon and a nucleon in iron. And keep some extra decimal places around. The difference will be smallish.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
