Show Energy Dissipated in Hysteresis Loop: Kavita's Question
  • Thread starter Thread starter janrain
    Energy Hysteresis
The area of the B-H curve, or hysteresis loop, represents the energy dissipated per unit volume during a magnetizing cycle. To demonstrate this, one can express the energy density as approximately |B|² and relate B to the magnetic field vector H and the magnetization vector M using the equation B = μ₀(H + M). By deriving M as a function of H, it is possible to perform a piece-wise integration over the hysteresis loop. This integration yields the energy density associated with the magnetic cycle. Understanding these relationships is crucial for illustrating energy dissipation in magnetic materials.
janrain
I would like to know how can one show that the area of a B-H curve, ie hysteresis loop, denotes the energy dissipated per unit volume during magnetising cycle.
I can't find this anywhere and need it urgently.
Thanks for any help.
Kavita
Consider strictly magnetic energy. You can give the energy density as ~|B|2. Then, you can relate B = μ0 ( H + M ), where H is the magnetic field vector (abscissa) and M is the magnetization vector (ordinate). Finally, you can use this to get M = f(H) and piece-wise integrate over the loop to get the energy density.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
