Energy/Light-Some problem set questions
  • Thread starter Thread starter jefgreen
    Set
The discussion revolves around solving two physics problems related to lamp intensity and distance. For the first problem, participants clarify the use of formulas for calculating intensity and illumination, emphasizing the importance of understanding the relationship between distance and intensity. In the second problem, confusion arises regarding the distance of a 15cd lamp from a wall compared to a 45cd lamp, with participants debating the correct application of formulas and the interpretation of time and distance. There is also a correction regarding the definition of lumens and candelas, highlighting the distinction between these units. Overall, the conversation focuses on clarifying the application of physics principles in practical scenarios.
jefgreen
Q1:
Two lamps illuminate a screen equally. The first lamp has an intensity of 12.5cd and is 3.0m from the screen. The second lamp is 9.0m from the screen. What is its intensity?
I know I need to use P=4*pi*(I), but there is no variable included for distance (d). Another formula given is: Eill=P/(4*pi*d^2). How should I go about solving this problem now?
Q2:
A 15cd point source lamp provide equal illuminations on a wall. if the 45cd lamp is 12m away from the wall, how far from the wall is the 15cd lamp.
Again, there is no variable for distance in the equation: P=4*pi*I.
d = v/t is wrong. It should be d = vt. Where did you get 343? you should be using the speed of light
For #1: d=vt.
d=(3x10^8m/s)(__t__)
What value would I use for t? I've tried everything...
bump. Please help me.
for #1, after you do the d = v * t using the speed of light, don't forget to halve the distance, since that's round trip.
What would my value for t be?
If the signal takes 0.003 seconds for the round trip, how long does it take to go up and how long does it take to come back down? :rolleyes:
half of 0.003?
The answer I have is: 450,000 or 4.5x10^5m
But, my instructor tells me the answer is 4.5x10^8
:confused:
And is my answer for #2 correct?
:confused:
Then your instructor is wrong.
It's useful to have a sense of scale. Earth is 40 000 km in circumference. Low Earth orbit (where the Space Shuttle orbits) is around 300 km from the ground. Geosynchronous orbit, the highest useful orbit, is 36 000 km from Earth's center.
So, my answer is correct?
jefgreen said:
Find the illumination 8.0m below a 405lm lamp. The answer I received was: .504lx. Is this answer correct?
Yes.
I know I need to use P=4*pi*(I), but there is no variable included for distance (d). Another formula given is: Eill=P/(4*pi*d^2). How should I go about solving this problem now? Lastly, I am cognizant that 1lm=1cd.
First, a lumen is not equal to a candela. A candela measures power per steradian, whereas a lumen measures total power.
Are you aware of the formula I=x/r^2, where x is power/steradian?
No, I'm not familiar with the latter formula. Is my answer to the Cape Canaveral question correct?
Yes.
Could you help me with my NEW #1 and 2 questions? Those are the last in the problem set our Physics teacher gave us.
ideasrule said:
Yes.
Thank you so much :smile:.
bump. Please help me with questions 1 and 2.
bump. Help please..
You should start a new thread if you want to ask new questions.
